I know this is aimed at large airplanes but I wonder if they could also be going after 100LL fuel too?
Which is funny considering all the old bugsmashers flying around burning leaded fuel probably put a higher person mile dent in the ozone than the average passenger airliner.
If I'm doing my math right...I would figure they put a much higher dent than airlines would. 150 people in a Cherokee ( let's say 7gph ) would be 6,300 pph of fuel burn. An a-320 with 150 ppl would be what? Like 3,500?
Part 43 is being re-written as we speak. From what I've read it's going to have some really great changes for less then 6000lbs 6 seats or less airplanes.If I'm doing my math right...
60 pph for 4 seats on a Cherokee, so 13 pph per person.
The CRJ 700 is around 3600 pph for 70 seats, which is 50 pph per person.
The Cherokee gets about 12 mpg, the CRJ only about 1 mpg
I doubt you'll ever see the death of the air cooled horizontally opposed piston engine in GA until meaningful certification reform is implemented, and that's a shame because they could be so much more efficient and so much cleaner.
Sent from my XT1254 using Tapatalk
23Part 43 is being re-written as we speak.
haha yup, 23. Light sport has some good stuff in there regarding certification, mx and modification. The disaster of light sport is that they are worthless airplanes with no payload and no range.23
I'll be cautiously optimistic, until I see it. Light sport is a disaster and if they use that as a model then it won't help.
In order for GA engines to become efficient we'd need liquid cooling, electronic fuel injecting and ignition. Two of which the FAA won't allow.
sure, also 60 devided by 4 isn't 13. 90 percent of my GA flying was not with every seat filled. Most GA is 1 maybe 2 pax and mainline (320-737) have less that 6k fuel burn. Also miles per hour count as well, 100 miles vs 460.If I'm doing my math right...
The FAA is forcing GA into mostly experimental because of this.Which in 1990 made sense, but not now with how far along the technology has come. I mean car manufacturers have figured out variable valve timing with selective cylinder deactivation and those engines keep running.
You're right I switched to 10gph at the last minute but forgot to change the outcome.sure, also 60 devided by 4 isn't 13. 90 percent of my GA flying was not with every seat filled. Most GA is 1 maybe 2 pax and mainline (320-737) have less that 6k fuel burn. Also miles per hour count as well, 100 miles vs 460.
I didn't think light sport was ever about payload and range - I thought it was intended to save recreational aviation - the guy wanting to go up by himself or with one other and fly for half an hour or so.
That won't save GA. Flying for no purpose gets old quick, and that's why you see the people that barely leave the pattern put 10 hours a year on. The people that I know that use their airplanes go places and do things in them that are either too far to do by car in the allotted time or accessible only by airplane.I didn't think light sport was ever about payload and range - I thought it was intended to save recreational aviation - the guy wanting to go up by himself or with one other and fly for half an hour or so.
