Inverted
mmmmmm wine
At what point during the stall/spin can you see the pilot heroically maneuvering the aircraft away from the propane tanks?
Oh snap. Do you mean she isn't a hero? Totally agree with the sentiments of your statement.
. . .and I'll respectfully disagree with you as well. . .simply because of the semantics of the word. So, educate me, please. If there's a possible "threat to life or limb," doesn't THAT constitute an emergency vice being in a stressful/difficult situation?
No. Absolutely not. Just because things are going wrong - perhaps several critical things - doesn't mean it's an emergency, nor does it justify declaring.
At what point do you reach out and say I'm in over my head, I need help? I certainly hope it's not when you're hitting the ground or you got yourself in too deep that hitting the ground is inevitable.
I don't understand the logic of what is worthy of declaring or not worthy of declaring? Figure out the paperwork later....and that includes figuring out whether your "emergency" was justifiable of not. I'm pretty sure 99.9% of the time everyone will be happy you're safe on the ground....No. Absolutely not. Just because things are going wrong - perhaps several critical things - doesn't mean it's an emergency, nor does it justify declaring.
That's the actual reason pilot certificates aren't given to monkeys and dogs, though both have shown proficiency in just flying even spacecraft....At what point do you reach out and say I'm in over my head, I need help? I certainly hope it's not when you're hitting the ground or you got yourself in too deep that hitting the ground is inevitable.
Main cause here seems to be the fact that she was in way over her head at a much busier airport than she should have been at it and then it just cascaded from there.
I had a similar scare related to freezing rain when I was a freshly rated instrument pilot (which gives you just enough experience, I hope, to get into trouble - not necessarily avoid it). Should've known better, didn't, ran out of performance with an airframe full of ice, effectively declared an emergency (I was no longer asking - call it whatever you want, the magic word was never uttered, but I took control), landed and waited out the weather.I remember very clearly, as a new PPL, with little to no appreciable instrument training, launching on a summer afternoon for a 141 syllabus "long cross country". Blue sky VMC day @ KEUG when I launched, same at KMFR when I landed after leg 1. Leg 2 was to KCEC. Got the weather brief, looked great and launched. Took my trusty Arrow in for some T+G's, and then started the return leg to KEUG up through the pass and through the rogue valley. About the time I got there, summer thunderstorms had drastically multiplied and solidified on the route. To the point where I was down to like 3k AGL below mountaintops trying to pick my way through, too low in places to pick up navaids. That was the first time I ever had to say "I'm over my head". Cried uncle to center or approach or whomever I was on flight following with, and they gave me some vectors that got me through the worst of it (and kept me VMC). Landed right before a big thunderstorm washed over KEUG. I think that decision, and maybe a little luck too, was the difference between an inadvertent VMC to IMC or CFIT mishap, and what happened which was a safe landing at home field. Though it was a lesson derived from my own mistake, that lesson has stuck with me, and is the little bird on my shoulder that always says "ask for help if you need it". In this case, turning around and going home would have been the equivalent decision I think.
By that logic every time the plane moves you should declare an emergency.
I was wondering the same thing in conjunction with the multiple reports of sputtering engine. Hard turn on low tanks cause fuel starvation when you need power most?Btw I'm wondering if fuel had anything to do with it, there was no fire and on the surveilance video you can clearly see the wing breaking open and no fluid (fuel) seems to spill...
