I have AOA, I know how it works, and I was willing to learn something new. What I am telling you, is that monitoring AOA takes a scan, and if you don't look at it, it does nothing for you. If you can't hold airspeed, or hold an ILS, then AOA ain't gonna help.
One issue is that your reference airspeeds can be wrong. Barring an AoA vane failure, AoA is not ever wrong. As you mentioned, the Vref approach has worked just fine for many years so none of us are suggesting that it is a have-to-have, nor are we suggesting this would have saved this crew.
How can my reference speeds be off?
Or you're not always at exactly 1.0 G'sIf you're heavier than you think you are, your ref speed will be less than 1.3 Vso, an AOA gauge will show you that.
Does your aircraft auto-calculate its own ref speeds, then display them?
No, but my plane tells me my weight, so I then look up ref speeds by that. If you want to split hairs and say that AOA will be more accurate by a knot, ok then.
My company has damaged a couple aircraft due to V speeds being off.So there's no potential for inaccurate weight calculation (which, of course, relies on manual entry of loads to begin with...which assumes that passenger counts, or cargo loads are calculated correctly, or annotated correctly on whatever paperwork used to enter into the aircraft system that calculates its weight), or inaccurate transposition of that calculated info into the bug speeds?
How many potential points of human error are there in that chain of events?
Big plane, lots of weight.JustinS said:How so?
Like you.Big plane, lots of weight.
Takeoff data related screw ups are nothing new, but they can be spectacular.And I here all this time I thought @Autothrust Blue was vague...
The lack of a written runway change procedure prior to takeoff is why US Airways crashed an Airbus a few years back.
I am telling everyone I can think of that we need to steal the boxed items from The Competition.The lack of a written runway change procedure prior to takeoff is why US Airways crashed an Airbus a few years back.
