FL350
Reverse is most effective at high speeds. Most modern jet engines spool quickly for reverse. However the burst of speed you mention when coming out of reverse too quickly I have only really noticed on the low bypass engine with clam shells. I have not noticed to be an issue at all on the larger bypass fans with translating cowls. I am assuming this due to only the fan air being reversed vs all the air air on the clamshells. I'm sure fadec may also play a part to.
@Derg aka Airbus guru what say you?
The book I learned this from likely wasn't referring to the modern engines of today. Personally I haven't noticed any small burst of thrust, but the dynamics of it make sense. It seems the E-jet takes a while to deploy and spool the reversers and thrust
