"Bout 3 fiddy"
We are usually too drunk trying to be the first to turn on our cell phones to careReverse is noisey and uncomfortable for the meat bags in the back. I use it sparingly. Never really considered the cost now that I think about it.
Yeeeeeeeeep. I know the performance data SAYS that I *can* land Flaps 5 and not use TRs at all in Santa Ana, but that doesn't mean I do it; it seems much more prudent to land FULL and use reverse until a safe stop is assured. Double ditto for Burbank. I don't want to have to explain why I didn't use all available resources to stop given the relatively short length of these runways, performance data notwithstanding.All this talk is silly.
If you depart the paved surface of the runway if you don't use brakes but use reverse you will be asked why didn't you use brakes as well as your reverse. If you don't use reverse but use brakes you will be asked why didn't you use reverse with your brakes.
They're almost certainly paid for nowadays..."Bout 3 fiddy"
I find on the jet I fly even popping the buckets provides pretty substantial drag. It's rare that we use full reverse though, unless the obvious situations.
Yeah, same sort of thing here, really. Ground spoiler deployment is automatic, and if you have autobrakes, by the time you get the reversers out you're in that "meh" range of speed where you can certainly get her stopped quickly. Assuming you're not skating on ice...I miss that plane, flew like a truck but amazing takeoff and landing performance. I don't think I ever used more than idle. By the time you get the speed brakes out, nose down, and feet on the brakes, you're already slowing through 65kts.
Don't do a whole lotta flying outside the U.S., do you? Especially Europe. Brakes and idle reverse, unless you need TRs to keep from departing the runway. Otherwise, it's a noise violation if you use them and didn't need to.Or just use both.
Works good, lasts a long time.
On my commute home however, it seems 737 drivers aren't happy until I'm eating the seat back in front of me upon landing with full reverse and heavy braking. Is it SOP on that thing?
So there I was deep in thought.
I can remember a guy telling me gas is cheap and brake pads are expensive.
However after aircraft ownership, and a few annuals later, brake pads aren't expensive. I got to thinking. For the amount of short field landings that I do on my bird, I use a lot of brakes, however I've only replaced the pads once.
Translating this to the transport jets and turbo props I've flown, how much gas am I burning from touchdown, using max reverse until 70 knots?
Multiply that across hundreds if not thousands of landings when brakes need to be replaced.
It is really cheaper over all?
@Roger Roger how often did you replace brake pads when we flew together?
Uphill runways. Between that and my idea for a fourth wheel on the tail cone of a 737-STRETCH, I'm an a roll today.
Let me rephrase. Haven't done a whole lotta flying to Europe, Asia, South America or Africa? Canada, Mexico and the Caribbean is what SWA calls "near international." Doesn't really count. Especially Canada.Actually yes I've done a lot of flying outside the U.S. Have you?
I never said full reverse, did I?
