cadbury
I have some technical questions on Piper Warrior II (PA 28-161). Need help.
8. When should the electric fuel pump be in operation?
a. Take off.
b. Landing.
c. Switching tanks.
d. All the above.
Is the answer "d"?
13. The PA-28 starter duty limits are
a. 15 seconds on, 1 minutes off
b. 30 seconds on, 2 minutes off
c. 45 seconds on, 2 minutes off
d. 60 seconds on, 5 minutes off
Is the answer "a" or "b"?
16. When flying PA-28, lean the mixture
a. When the outside air temperature is above 75 degrees Fahrenheit
b. At or below 75% power
c. During cruise operations
d. Only b and c apply
Is the answer "d"?
22. Loss of alternator output is detected through zero reading on the ammeter and illumination of the ALT light in the announciator panel. Before taking any emergency action, ensure the reading is actually zero, and not simply low, by actuating an electrical devices such as the landing light. Then :
a. Decrease the electrical load as much as possible and check the alternator circuit breakers for popped circuit
b. Attempt to reset the over voltage relay
c. Land as soon as possible if the alternator can be returned to service
d. All of the above is correct
Is the answer "d"?
26. One of the precaution to be adhered when towing an airplane with power equipment is
a. Always locked controls or control surfaces prior to towing operation
b. Do not turn the nose gear in either direction beyond its steering radius limits
c. Always disconnect the nose gear torque link prior to towing operation
d. All answer are wrong
Is the answer "c" or "d"?
32. Landing gear wheel bearings are inspected, cleaned and repacked at an interval of
a. 25 hours
b. 50 hours
c. 100 hours
d. 150 hours
Is the answer "b" or "c"?
_______________________________________
Please fill in your answer
8( ), 13( ), 16( ), 22( ), 26( ) & 32( )
a. Take off.
b. Landing.
c. Switching tanks.
d. All the above.
Is the answer "d"?
Is the answer "d"?
Is the answer "d"?
a. 25 hours
b. 50 hours
c. 100 hours
d. 150 hours
