Well to be fair in their quest for modernity Airbus seems to have made their share of missteps.
At least they're trying!
Still trying to figure out why a FBW aircraft has a trim switch though...
I don't know, seems like it'd be nice if you ever stooped to hand flying, but then again the bus has that auto trim magic from what I understand and maybe once you try that the trim switch becomes superfluous.At least they're trying!
ORLY? I don't remember my time on the -200, but that seems to be an idiotic design.
ORLY is an airport in France
I'm not allowed to comment in public on that nice 737 "feature".
TP
It doesn't make any damned sense.
So technically speaking, you could initiate TOGA, the autopilot clicks off and during all the confusion since the plane is trimmed fora particular airspeed, it's technically going to pitch up to maintain that…more or less.
Do you mean the trim wheel? Or talking about something else?
TP
Nah, the thingy on the yoke, for example, the 777.
In it's initial design, it wasn't there but the design team at "Snacks R Back" wanted a more conventional setup.
IIRC, in my whopping ten hours of 737 sim, there is no TLA/thrust compensation on the 737, either.
That said... and forgive me for saying this as the most junior of the most junior... fly the g-d airplane!
Did you read the part in where in sim the AT pilots always do approaches with both channels engaged for the coupled missed, but on the line they only ever use one channel?
-Fox
It's no jet, but the SAAB is the same as the 737 when you press the toga buttons, the ap disconnects. The FD pitches up to 6.4 degrees, but there is no autopilot. You actually have to fly it up to the command bars. But at least you get go around power with the flip of a switch.It doesn't make any damned sense.
I missed that. Why would you not just do all coupled approaches with both/all(how many in the 737?) channels engaged to make this a non-issue? Going to my extraordinarily short time in the 747, if you have 1 engaged, they all(3) arm when you hit the approach button. If you hit TO/GA with no AP/FD it brings up the FD, and I went back and looked - it makes no meantion of what happens when you hit TO/GA with only 1 AP active on approach(which would not be a normal situation), but in climb and cruise phases it would not turn off the 1 channel, so I don't know why it would on approach.Did you read the part in where in sim the AT pilots always do approaches with both channels engaged for the coupled missed, but on the line they only ever use one channel?
-Fox
Always fly the airplane.
However the ever present threat is knowing what level of automation we're in (or not at all) and it's too often a fatal error.
Hand-flying isn't the answer as that's a whole different chapter in the book of "Murphy's Law". Fully coupled, is another chapter.
It really seems that the road is leading to a good discussion on "Human Factors".
When I was on the 737, you'd only activate the other autopilot when you're doing an autoland. Granted this was back in the… uhhh…. early 2000's and I'm sure the procedure has changed a zillion times.
Same in the 757/767.
In the bus, we couple them both just out of procedure and "Momma says DO IT" so we do it.
We did have some situations at my employer which changed our procedures to visually and verbally verify that the plane is performing as expected during a missed approach/go around in order to mitigate that error across all of our fleets.
Okay. By 500 feet if the AP is still on, your intentions should be to autoland. I think that's a touch late to take it and have a normal approach to landing.The reason why people don't do dual channel approaches in the 737 is because it pretty much had to terminate in an autoland unless you kicked off the A/P before 500 feet. At 500 feet it spun in something like 5 units of nose up trim to assist in a go-around... which things could get sporty if you turned off the AP once the wheel of knee ouchies had done its thing. Yet another part of a really dumb design.
