Not "call this number" but I was driving along one day when my cell rings. "Hello, this is [name withheld] with Denver Tower."I've had a tower controller give me the number because he wanted to see if anyone at our flight school wanted fresh vegetables from his garden. That guy was awesome, but it does get you mind running trying to figure out what you did wrong.
It really depends on the facility that gives you the number and the circumstances. Most controllers are not out to violate pilots, some are. If you get the number from a Class B TRACON, that is probably the time to be most worried. 90% of the time it is the result of some sort of confusion and the controller just wants to talk to the crew off line to figure out what went wrong and make the skies safer from both sides. Sometimes a full Brasher can't be avoided thanks to a nosey/overly jealous supervisor. In 5+ years in the agency I have only seen 3 serious Brasher warnings issued. One was given after a deviation that involved a TCAS RA, one involved a pilot in non-radar airspace giving a false position report, and the third probably wouldn't have been one except for the supervisor overheard what was going on, and it may or may not have been a pilot deviation. We rarely find out what happens after an investigation, or if there is one at all.
Mark has a nice presentation there in his post. I'll add a few points since I have now seen it from both sides.
If they issue a Brasher, it's because they are mad or because they are required to, but they are not likely thinking about getting your certificate revoked; they probably want the supervisor to chew you out on the phone. If you are apologetic, it will likely go no further, unless a loss of separation occurred, as the supervisors probably don't know much about pilot certificate action either.
Even if you hear "possible pilot deviation," it may not be cause for excessive concern if you know you weren't committing any egregious errors. That language is part of the Brasher statement that is printed on little boards next to the scope so controllers can just read the statement to you without a lot of thought.
What if you don't call?
Last time I talked to ATC they had called our arrival gate to apologize for a really "crappy" loss in separation that they directed.
Does he work at Delta now?When I was instructing at Willie years ago the tower (contract) gave one of our instructors a number to call after he landed. He had no idea what he'd done wrong and was really worried about it. Turns out he was their 100,000 operation of the year and they wanted him to come up and share some cake with them.
Does he work at Delta now?![]()
Just be advised that some deviations are automatically reported (AKA "the snitch"), and that the controller has little or no say if they get escalated or not. They go directly to the supervisor's desk and it gets worked from there.
Lateral deviations on RNAV departures are a favorite for this kind of thing. I know Pilot McStudmuffin likes to hand fly, and that's cool and all, but if you get off the track JUST a little bit, you are setting yourself up. There are plenty of opportunities for hand flying, but blasting out of Hubsburg in the clag when they're doing triple RNAV departures probably isn't the best time. Just sayin'.
Richman
Do aircraft limitations play a factor into the overall decisions? I dont even have
An autopilot currently, and certainly wouldnt attempt a departure or approach outside what Id consider well within the plane and my own ability. But that being said, ILS or RNAV, Id figure if needles wouldnt go full deflection on me I wouldnt expect "the snitch" to pick it up. Its all hand flying for me, at least a couple hundred more hours.
Unless you're flying a turbojet/turboprop you're probably not going to be flying an RNAV departure, so I wouldn't worry about that end of it.
However, slightly less than full deflection on approach, in some cases, might pinch you. I'm not talking about shooting the VOR approach into Broken Bow, Nebraska, but somewhere busier, like shooting the RNAV or LOC into Hawthorne (HHR), which is right next to LAX. Or maybe going into somewhere that has traffic on the parallel approach.
If you're just GA put-putting around, then your exposure to this kind of situations is somewhat limited to non-existent. But an altitude bump that causes a loss of separation IFR will almost certainly get caught by the snitch. Busting a class B without a clearance will get you snitched. What the supervisor does at the point is a answer better left for the actual ATCers around here.
This is nothing new. The snitch has been around since the early 90's at least. What ATC does with that info HAS changed over the years, ranging from nothing to "the Deathstar is clear to planet", so your mileage may vary. IMHO, they'll probably give more slack to a part 91 GA guy in his 150, than a 121 crew, but there will be some minimal level of interaction.
Richman
Actually did that approach into HHR about a week ago in IMC....guy wasnt too pleased i busted minimums by fifty feet for a second or two while i was being bumped around, but he I imagine took pity on us when he figured we must be a training flight.
I'd be surprised if he noticed, altimeter is only accurate within 75', plus allowable error in the TXPDR, etc. The general rule I've heard is 300' off an assigned altitude is the threshold for a Pilot Deviation.
When it comes to separation issues, I've had the most challenges in places like MYF and CRQ, I've been flying planes that fly 60-130-KTS on final. Go the LAX etc and everyone is a lot closer in speeds, and closely managed by ATC, so stay sharp in the Skyhawk.
