Roger Roger
I am le tired
The bushing into the rear wing spar attach on the fuselage has the bolt hole drilled off center.Please educate as you are clearly in depth
This means that as you rotate that bushing, you change where in the fitting the attach bolt goes. This in turn changes the height of the aft spar attach point relative to the fuselage changing the angle of incidence. Let's say you have a heavy right wing. You would rotate the bushing in that wing so that the hole is as low as it will go. This will bring the trailing edge down, increasing that wing's angle of incidence and in theory making it less wing heavy. It's a real pain in the neck though as its a split bushing and the 2 halves are really hard to get to and you have to make sure you rotate them in synch.
On the flaps, your fault is in thinking that the flap track is what limits flap travel. It's not. Travel limits are set by limit switches and you should never use the full track as you'll start bending and breaking stuff if you run the flaps all the way to either end of the track. There is plenty of extra slot on bit the up and the down to allow for manufacturing and repair tolerances in individual flaps. The flap rigging I refer to is most often done by simply adjusting the rod end(s) on one flap to make it sit up or down farther than the other one. It's often used as a field shortcut around then painful process of adjusting wing incidence, however doing so can induce a roll and/or yaw when flaps are extended. It's not really an approved procedure on the cessnas, however it's THE way it's done on the Cherokee family (they also make it very easy by using opposite threaded rod ends at both ends of the flap pushrod, so you just rotate the pushrod to shorten or lengthen it. The Cherokee is my favorite airplane in the world to rig because it's so dang easy).
Hopefully this was all illuminating as it can be sort of hard to communicate the intricacies via typing on a phone.
If not, you're more than welcome to drop by my shop during annual season and I'll give you an in person demonstration.
