Roger Roger
I am le tired
GA guys, do you ever get tired of having crap break on you then learning that it's the same crap that's been breaking in the same ways for 20 years, and manufacturers still haven't fixed it? Makes me want to spam SDRs.
They have drop in electronic breaker point eliminators for old cars, seems like we could, you know, have the same thing.Just little stuff here and there. I mean for example you'd think that by this point they'd have magnetos pretty well figured out, but we've seen a removal rate as much as 25% before normally scheduled maintenance.
Oh absolutely. On a turbo motor that can easily run near detonation having a brain to vary timing would be much safer anyway. Otoh with the quality control I see from piston OEMs even going to electronic doesn't necessarily give me warm fuzzies.Well the feds could also pull their heads out of their ass and let us go to digital ignition. Since things that move a lot tend to fail a lot more than things that don't move at all.
The one's available for the experimental market have a fantastic safety record. All of the systems I've looked at have real world MTBF well past the life of any piston engine.Oh absolutely. On a turbo motor that can easily run near detonation having a brain to vary timing would be much safer anyway. Otoh with the quality control I see from piston OEMs even going to electronic doesn't necessarily give me warm fuzzies.
Fair enough, but let kelly aerospace make it and I'm sure your MTBF will drop drastically.The one's available for the experimental market have a fantastic safety record. All of the systems I've looked at have real world MTBF well past the life of any piston engine.
Couple that with EFI and you have IO-360's putting out 250+hp running cooler CHTs and burning a lot less fuel.
Oh honey I would give a kidney to have bent cowl flaps the the biggest of my problems.Having seen an ELT 'battery' I'm not surprised.
Bent Cowl flaps was one I saw fairly often too.
I jelly bro. At least today.I'm so glad I'm a MINO.
None that I know of. The two places in the state that do multi training that I know of is rocking a Twin Commanche and the other place has a Dutchess.Has anyone ever seen a Seminole in AK?
I thought UAA had Seminoles.None that I know of. The two places in the state that do multi training that I know of is rocking a Twin Commanche and the other place has a Dutchess.
Forgot about those guys.I thought UAA had Seminoles.
Ya there's quite a few, but you still have to keep a magneto in every installation I've seen, which negates almost all of the advantages. Fixed timing is the biggest problem.There is an electronic ignition in the STC market. Spencer Suderman did the R&D on his Pitts for the -540 approval.
