http://www.foxnews.com/world/2015/0...rashes-in-germany-pilot-ejects/?intcmp=hplnws
Not been a good stretch for the 16 world.
You mean the last 35 years?
There's a reason for the "lawn dart" nickname.
Talked to an old test pilot once an that name came up. It is amazing how long people kept flying them with P&W looking at them going "I don't know why the engines keep failing."
Apparently it took a guy losing his engine on climb out and having enough altitude and testicle fortitude to flip it around and land it to let them figure it out.
Solution.... Buy GE Engines.
PW motors weren't the problem really......still plenty of block 32/52's flying around just fine with them, as well as all F-15C and a decent portion of the F-15E fleet (though many are now -229 powered). The issue was the initial motor, the F100-PW-200, had a ton of rollback and locked-in stall problems early on, causing a rash of accidents. The EEC (analog FADEC) was replaced in the F100-PW-220 with the DEEC (digital version of this early FADEC), and the problems pretty much went away starting with the block 10/15 -220 equipped jets. I believe the early F-15A's had the same issue, with the same motors. The -220 isn't a bad motor at all, pretty simple, reliable, and with the digital engine control (PRI mode) it will generally keep you out of trouble. SEC, or the backup system is a lot more needy, but that is really just a "get-home" type of system if something major has already gone wrong with the motor, DEEC, or ignition. At least I have yet to have one, or know someone who has had one, poo the bed on them. I have a couple friends who have had a SEC reversion, but that really isn't a big deal......just shoot a straight in to a long runway and don't land long (nozzle stays closed for "get home" purposes so you have way more thrust at idle than in PRI)
Well for sure the GE motors are the ones you would like to have, at least for the power output, and hell, they make almost every other engine for US fighter aircraft. I had a GE (F404) completely run out of oil and there was no damage whatsoever to the motor.......though I did shut it down after the caution came on. However, in terms of PW motors, I'm surprised they never fitted the F-15C with the -229. That is like the mother of all F100s. I heard they test fitted it/test flew it in the airframe, but it didn't go anywhere.
They would probably be better off with just taking the CFTs off of the E model... as far as airframe goes.
Our 229s are pretty solid motors. For how much fighter engines get abused and cycled, it's pretty amazing how reliable they really are. You can definitely feed the difference in the -229s over the -220s.
