deltabobo
Wingman Extraordinaire!
"Cough, cough, Allegiant, cough, cough..."Anything can be a suitable runway if the pilots are brave enough
deltabobo said:"Cough, cough, Allegiant, cough, cough..."
Its actually pretty easy. Its either 300-3/4 or 200-1/2 depending on CAT II/III availability.Don't forget the add-ons for CAT II/CAT III Mins...Oh my!![]()
Yeah, thats how we do it.Yeah but isn't CAT || / ||| as is with no adding ?
Cough, cough, Atlas cough, cough....
Well played for the Rwy 27L/Twy N similarities!Cough, cough, Delta cough, cough....
Might as well throw Continental on RWY 29/Twy Z also.Well played for the Rwy 27L/Twy N similarities!
PM sentYeah... everyone posted sufficient information about this NAV 1, 2 NAV rule. I just needed someone to explain it to me like I am '5' years old. I am still in Aircraft Dispatch school, and just wanted to know what it meant. I heard many airlines wanted their 'new-hires' to have a good idea of what the NAV1 NAV2 rule is.
Thanks for the info. I would like a more basic understanding for the rule if you all could.
Assuming those two approaches use different nav-aids.You stated that you had firm grasp on the 121.617 and 121.619, so I won't try to expand on that. 121.619 originates from 91.169. Within 91.169, it states that for an airport to be listed as an Alternate it has to meet the
"airport minima specified in that procedure, or if none are specified the following standard approach minima:
(A) For a precision approach procedure. Ceiling 600 feet and visibility 2 statute miles.
(B) For a nonprecision approach procedure. Ceiling 800 feet and visibility 2 statute miles." These are typically found on the Airport Data pages.
121.619 points towards 121.625 (which allows carriers to deviate from 91.169 per what is defined within the OpSpec). Most all carriers have the 1 Navaid, 2 Navaid rule (and some CAT II/III) to obtain mins lower than the Standard IFR Alternate Minimums.
For Example(assuming no restrictive NOTAMS): I have a flight from FLL-BOS. BOS is currently BKN010 and forecasted to be BKN008 throughout the entire TAF period. All of New England is forecasted to be BKN006-BKN008. Using the Standard IFR Alternate Mins, I'd be looking for an Alternate to list somewhere within NY state area. Using the 1 Navaid, 2 Navaid rule, I can list PVD as my ALT because the ILS 5 and 23 give me 400'-1sm. Side note: listing a far ALT requires more fuel (obviously) and depending on one's airplane performance, you might be bumping a few pax and/or bags.
Hope this helps.
It could be misinterpreted as class I and class II navigation.My only suggestion is to call the rule by it's proper name, not NAV1, NAV2.
It is called "1 Navaid, 2 Navaid Rule"
Might seem like splitting hairs, but the incorrect way is somewhat misleading and might make some people think you're referring to something else.
