Letting the EFB "be all the EFB it can be..."
Tram
Ok guys-
So the owner of the Cheyenne I'm about to fly has told me to decide how I want to handle pubs while I'm managing the plane.
I'd like to go EFB. Seems like there is no reason not to, in this day and age.
Rather than make this about which EFB to choose, what I'm wondering is what are the essential items to let an EFB be what it can.
I'm assuming up front:
An iPad.
A data subscription to said iPad.
A subscription to a pubs servce - ForeFlight and Garmin Pilot are the front runners right now.
Outside of these 3 basic things, what do I need to get up and running?
Thanks
If you are going to dedicate an ipad EFB for one plane, I would recommend getting a compatible ADSB receiver such has a Stratus.
ADSB is going to be handled early 2016, so I'm definitely looking that direction, just need to decide what unit to look into. I'd love something that would link up to the Avidyne EX500, but I dunno where to even start..
I really think I'm leaning towards Garmin Pilot right now over ForeFlight and then worrying about ADSB out as we get closer.
I think you got all you need. Might want to look into a yoke mount, or some other sort of mount, especially if you're flying single pilot.
Yoke mount and iPad Mini as long as it doesn't block instruments. Most airplanes I don't believe it would. Otherwise a suction mount to the side glass panel could also work well. Glareshield clamp is also an option. If you really want to spend the money, there are hard-mounting options available as well. Foreflight is IMO the best solution out there, Jepp's EFB product costs more and does less. FltPlan Go i've found to be a little clunky but it will do everything Foreflight will, for free. There may also be an app for your airplane to do weight and balance and performance calcs as well.
Yeh, I'm not a huge fan of yoke mounts. I'll figure something out for the mount setup in the near future.
Upgrade the airplane clock to the dual USB port clock from Mid-Continent Instrument. Probably the easiest way to get ship power for the iPad so you can leave the screen on for the entire flight if you plan on using it for traffic.
If by any chance you're flying International, try FLASHPASS. Easiest EAPIS handler around!!
Wow. $600 for the clock. That's a serious time piece. ;)
Worth it IMHO. We don't have the clock but we do have their USB only brick ($300) and it's a great little product. TSOd and everything, depending on your FSDO usually just a logbook entry for paperwork.
Better, get one of the ADSB in-out boxes on the market now that will wifi to the tablet. A Cheyenne glare shield isn't really big enough to have antennae and crap bouncing around up there and it sounds like they're doing ADSB anyway, so might as well kill two birds with one stone.
You can buy lots of cigarette plug chargers for $600!
Tell me about it! ;)
I'll have to talk to the owner. We aren't shopping with my wallet, may make good sense to him. ;)
That's ideally what I'd like to do. Plane is tentatively expected to go down in early '16 for ADSB.
First figure out if you want Jepp place or NOS plates?
STC or non STC'd install? Might want to see what it is going to cost for approval if you need it.
ADSB
A kneeboard ipad holder might be a good option vs. a mount. Easily moved if its in your way, and gives you a hard surface to write on if you need it.
And personally, Fltplan Go > Foreflight.
I wasn't a fan of the yoke mount with a full-sized iPad, but the Mini works very well - it's not much larger at all than a standard chart, doesn't block instruments.
I have tried a couple of different iPad kneeboards and what I've determined is that I prefer the yoke mount more where possible. On an airplane with a stick (Citabria) the kneeboard is good. I like the aluminum one that closes OVER the ipad....can't remember the name of it but the guy on the MzeroA youtube channel reviewed it and it's what I ended up buying.
I love this setup, very convenient and accessible but doesn't get in the way. The only issue I have is prolonged periods of sun exposure causes the iPad to overheat and shut down.
Yes, also hard to read in the very bright sunlight. I think some sort of add-on visor/hood for the yoke mount would be nice.
