OEI obstacle clearance
FL350
As you all probably know; transport category aircraft are required to have procedures for engine inoperative climb to clear obstacles on departure. This does not mean complying with the requirements of the SID or ODP.
This is required under part 135 subpart i, and same with 121.
How are operators complying with this in practice? It is my assumption that many 135 operators are not in compliance with this. And it would probably be smart for 91 operators to follow this requirement as well.
The only way that I'm aware of is to use an airport analysis product such as APG. It's relatively cheap and easy to use.
Not sure I follow the bold. I have never flown 135, but 91 I follow the SID or ODP and just make sure I meet the climb requirements SE. For the CJ1 I use CESNAV on the iPad. It bases climb performance on OEI. Obviously there is no requirement to do so under 91.
There are products out there that have custom OEI procedures for each airport if that's the way you want to go.
TrustMeI'maPilot said:
Not sure I follow the bold. I have never flown 135, but 91 I follow the SID or ODP and just make sure I meet the climb requirements SE. For the CJ1 I use CESNAV on the iPad. It bases climb performance on OEI. Obviously there is no requirement to do so under 91. There are products out there that have custom OEI procedures for each airport if that's the way you want to go.
Gimme a few minutes to get home from the gym and I can show you how your thinking is a product of very poor 142 school house instruction
Hey @Dugie8, I'm really interested to see what you have.
Sorry, sorry. Got home last night and proceeded to puke my guts out. Stupid Gas Station sushi.
Ok, talking transport category jets here, nothing more. 135.379 ((2) For an airplane certificated after September 30, 1958 (SR422A, 422B), that allows a net takeoff flight path that clears all obstacles either by a height of at least 35 feet vertically, or by at least 200 feet horizontally within the airport boundaries and by at least 300 feet horizontally after passing the boundaries.) The sister reg under 121 reads almost verbatim, if not verbatim.
To put it simply, you have to miss the obstacles and KNOW before you take off that you will miss the obstacles. Seems simple, yet folks still cling to "see and avoid" and "VFR departures". Neither exist under 135, at least in the context that you can ignore take off performance limitations, ie weight.
So, most, if not all, 142 schools, CAE, FSI, SimComm, etc, teach this as all you have to do is make sure your second segment climb performance is equal or greater to the SID climb gradient requirements. Sounds good at first glance BUT you have to consider most airplances Second segment end at 1500 feet then you nose over and accelerate (3rd segment), clean up and then climb at Venr or some other term (4th segment). Now when someone points this out somebody likes to be smarter than the system and says, "Well I'll just look at the second segment performance at a higher altitude, ie take off from a 1500' MSL field and the SID tops out at 3500' MSL, so they look at second segment performance at 3500' MSL". No Bueno. You can interprolate you cannot extrapolate a chart. Meaning, that isn't how the chart is meant to be used and that isn't how the airplane is going to perform. You need to take into account things like ground effect, engine power reduction/loss, etc.
Dugie, where the hell you going with all this. Glad you asked!
TERPS is for all aircraft, not just us jet drivers. TERPS starts at the end of the runway (35 feet above it) and goes out for 200'/NM. It's a sheet of plywood that you should not penetrate. That rate goes up depending on obstacles. Let's go back to the 3rd segment climb thing. More than likely that nose over and acceleration will put you on the wrong side of the plywood. So your 2nd Segment climb from gear retraction to 1500' or so may exceed the SID requirement, right up to you nose over, then BLAMMO. Granite. Also you have to take into account your climb penalty for turning.
So what does APG do, again Good Question. APG says, HEY! Even with an engine failure at V1 very few jets are going to cross the end of the runway at 35 feet. We will start your climb gradient from where the AFM says you will be with an engine failure, ie distance down the runway. Imagine a TOFL of 4000 (accelerate go) on a 9000 foot runway. Lots of real estate between you and where TERPS thinks you are. So you may have the same paultry climb performance on one engine but you just bought yourself another mile or so before you even come close to an obstacle (not a lot of towers right on the runway).
Most of these APG procedures are either fly a heading after acceleration altitude or they simply overlay the existing SID/ODP. The lateral track is easy, APG does all the magic for the vertical track.
Could you figure all this out on your own. Short answer, no. While we have all the charts to calculate all those segments, we don't have all the obstacle data. TERPS takes into account the big stuff but not the low close in stuff. Let that sink in for a moment. There could be obstacles out there that penetrate your departure path and you don't know about them but APG does. Thus APG is not just for "mountainous" airports, it is for EVERY, DAMN, TAKEOFF.
I keep using APG but there are other providers, APG is just what I am familiar with.
Hope this helps
Hope this helps
Thanks, now I understand what he is talking about. Like I said, I've never flown 135 so was responding with what I do 91.
Hope this helps
Because of everything you said, I used to give my pilots an event in the sim that would hammer home having an escape plane when flying the ODP in airplanes that aren't required to show single-engine climb gradient. The event I used was taking off in MCG on the ODP with an engine failure right as you enter the clouds in the Navajo. If you keep desperately trying to fly the ODP you will hit a mountain. Some guys saw this and maneuvered on the terrain page of the GPS, other guys were so busy with the engine failure that they flew right into the hills.
The big thing is that you should always in every airplane, have a plane for what you're going to do prior to takeoff. It's also worth noting that no matter what airplane you're in, you must fly an ODP or an ATC assigned departure procedure under 135. I don't know how many guys I've seen blithely get to 400' AGL and turn on course out of airports with obstacle departures. ATC generally doesn't care - and truth be told, they may not even be expecting a guy to be flying the full ODP most of the time. I've found that a lot of controllers don't seem to expect you to be on the ODP, and may even query you about your intentions when flying it, but as soon as you say you're on the ODP they usually say, "Oh, no problem."
The best advice I can give is to have a plan in any airplane for avoiding hitting things when you lose an engine. The ODP is only part of the picture in some cases and in certain airplanes, you may not be able to safely follow it after an engine failure on departure.
ppragman said:
Because of everything you said, I used to give my pilots an event in the sim that would hammer home having an escape plane when flying the ODP in airplanes that aren't required to show single-engine climb gradient. The event I used was taking off in MCG on the ODP with an engine failure right as you enter the clouds in the Navajo. If you keep desperately trying to fly the ODP you will hit a mountain. Some guys saw this and maneuvered on the terrain page of the GPS, other guys were so busy with the engine failure that they flew right into the hills. The big thing is that you should always in every airplane, have a plane for what you're going to do prior to takeoff. It's also worth noting that no matter what airplane you're in, you must fly an ODP or an ATC assigned departure procedure under 135. I don't know how many guys I've seen blithely get to 400' AGL and turn on course out of airports with obstacle departures. ATC generally doesn't care - and truth be told, they may not even be expecting a guy to be flying the full ODP most of the time. I've found that a lot of controllers don't seem to expect you to be on the ODP, and may even query you about your intentions when flying it, but as soon as you say you're on the ODP they usually say, "Oh, no problem." The best advice I can give is to have a plan in any airplane for avoiding hitting things when you lose an engine. The ODP is only part of the picture in some cases and in certain airplanes, you may not be able to safely follow it after an engine failure on departure.
Kmkc is a great example of an Fitch with an ODP
Runway 01 I think has a climb in a heading to an altitude then on course.
Tower is notorious for giving you a heading in the other direction than the ODP.
Bad juju.
Bad juju.
Doesn't a tower vector take the place of (or "override," for lack of a better word) an ODP?
Per the AIM:
Aeronautical Information Manual said:
ATC may assume responsibility for obstacle clearance by vectoring the aircraft prior to reaching the minimum vectoring altitude by using a Diverse Vector Area (DVA). The DVA has been assessed for departures which do not follow a specific ground track. ATC may also vector an aircraft off a previously assigned DP. In all cases, the 200 FPNM climb gradient is assumed and obstacle clearance is not provided by ATC until the controller begins to provide navigational guidance in the form of radar vectors.
