I can't imagine there would be any routine or logical reason to knowingly taxi in like this. That's why I'd like to know more.
According to flightradar24, the a/c did a maintenance turn to Tulsa before the DFW-GIG leg. No subsequent activity since the incident flight, so it appears to still be in Brazil.Anymore actual info about this?
No clue.
We had a single tire rupture (I can't in good faith say, on the internet, say I blew a tire because there's always someone named "tire" I guess) during a high-speed RTO in SLC about a decade ago. Maintenance came out and suggested we taxi, very slowly, to the gate.
I think it just all depends on the situation.
My recollection is that some sensors are a factory option (e.g. brake temperature readout; is there a limitation for that, or just the quick turnaround times?) I cannot comment on how this aircraft was equipped, so it's possible nothing was displayed.
This was Brazil, so perhaps the crew is in jail awaiting trial.
One tire out of 4 on a bogie is one thing....and following inspection by maintenance. All four tires on a bogie that is still smoking, no inspection done, the metal grounding on the concrete and no idea of other damage; I have a hard time seeing how taxiing with pax onboard could be any kind of conservative option, pending the blowout was known, however....
Why do you say that?
We had a post with lovely Brazilian women, but it got deleted...Have you seen Brazilian women? Ain't nobody got time for blown mains.
Yes, we decided against "JC Teen Forum".
Captain said "It's a Boeing. We're still going."And I find it hard to fathom how the pilots didn't know all the right mains were gone. First clue is a call from the head flight attendant: "Captain, the drinks in first class are all sloshing out of the glass to starboard."
That bogie is finished. Axles in all likelyhood are heat damaged. Hydraulic lines and wiring heat damaged. Look how close the brake torque links are to the ground, more than likely damaged. Your going to have to jack the wing just to get a jack underneath the bogie to change all four tires and brakes. Who knows what you'll find when you get those off. Best case, change tires and brakes and ferry it home. Worst case complete gear change in Brazil..
Not to mention what happens if they get to the gate and something ignites- now your doors are disarmed and the pax terminal is at risk.
Exactly. You're asking for a fire to erupt, taxiing in like this with unknown/unchecked damage. Absolutely no reason to. I'm all about benefit of the doubt, but I have a hard time believing the crew wouldn't be aware of what's going on or that something is damaged down there. And not only to taxi the damaged plane as was, but to do so with pax aboard with all the unknowns and potential dangers.
I'm just curious of any SOPs that would direct or allow this practice. I couldn't think of any existing, at least anywhere I came from. Any 121 guys aware of any here?
Agreed. A plane catching fire at the gate is not just an aircraft fire, it now one with structure exposure, if the fire can' be immediately contained/extinguished in the wheel well.
Don't know what all the fuss is about- there is still plenty of rubber on all the wheels. The problem was low pressure in the tires, hence contact from rims with the ground. I'm sure AA maintenance just needs to to put enough air to get rims off the concrete and she's good to fly back out. My concern on walk around would be how to get all the concrete dust, debris off the gear assembly- looks like a piece of equipment that's been sitting outside in the desert for ten years.
at picture #2 how exactly the wheels follow the white guidance stripes, just perfect.
