That's the point -- we're NOT talking about the "shortest runway possible". We're talking about LONG runways, where maximum effort braking is not required, even at higher speed aborts.
I have flown jets with ridiculously incapable braking systems (as in no antiskid) compared to the weights and speeds involved. It was never difficult to look at the brake energy chart as part of the TOLD review and know what the risks of a very high speed abort were in those terms. With very long runways, stopping technique was part of the discussion.
It would be VERY easy to have overlapping data which said "at abort speeds above XXX KIAS and XXXX gross weight, braking capability is significantly reduced".
IMHO, still not a good reason to not compute TOLD based on actual runway length.
How long are your brief periods for a sortie?
EDIT: Let just me get to the point I'm trying to make, and I'll make an assumption regarding your brief.
My guess is that you guys have a much longer period of time to brief your flights than we do. We'll take a plane, and from blocking in to blocking out, turn it in under 30 minutes. That includes a post flight, getting the paperwork, making sure the paperwork is legal, programming the box, getting a clearance, blah blah blah. There are a lot of things to do in those 30 minutes.
To spend time determining how you're going to do the aborts, and then REMEMBER how you briefed you're going to do the aborts, is time we don't have. And frankly, it's brain power we likely don't have. To steal a line from George Carlin; think about how stupid the average pilot is, and then think that half of all pilots are stupider than that guy.
Our procedures are based on efficiency and safety. Safety comes from doing things the same way, ever time. So when the skipper says, "We'll abort for anything below 80 knots, and between 80 and V1, we'll abort for engine failure, fire, loss of directional control or an inability of the aircraft to fly, and above V1 we'll take the aircraft flying and treat any problems as an airborne emergency," you're on the exact same page. You've been trained for doing exactly that, and the skipper has briefed exactly that.
It's simple to the point that a caveman can do it, and we've proven over time that it's safe.
Is it max performance? No, but nothing we do is max performance. We derate our takeoff thrust so much on 90% of our takeoff's that we're dealing with a fraction of the thrust the engines can produce. We're not looking to employ our aircraft as a weapons platform, we're looking to employ our aircraft efficiently, and that requires some standardization.
