bigD1031
You'd need a 25 pin jack on some of them, and I think the 777 has a USB but I don't think there's one in the AV compartment. Once you get in you can't edit flight parameters. I'm going off memory here and that wasn't really my focus but it was something we had to deal with testing boxes that needed to monitor inputs/outputs of the boxes. Normally it involved a lot of transformer and MOV isolation so we didn't fry the laptop AND the box.
So the next thing you'll need a hacker who is familiar with proprietary software, and (essentially) driver code. Using his stolen password of "Jeff" (The writer of the program's name is Jeff Jeff'ty Jeff born in Jeff, Jeff in nineteen-Jeff'ty Jeff), he hacks in and changes all the parameters of the flight control computer and lowers the G/S to 2.00. The entire plan goes to crap because he just figured out he needs to get all three independent computers to show the same thing at the same time and he only brought one laptop. The system is just doing too good a job ignoring the new crap info (from the hacker's laptop) that doesn't gel with the other ADC's. So he takes his penknife he snuck aboard and snips the blue wires on the other two ADC's which feed information into the central unit (whatever it's called on this airplane) which integrates all the information from all the systems. Plot twist: he's been color blind since birth and never knew it so, the wires were actually the dreaded red wires.
Finally, after snipping the dreaded red wires on the ADC the computer naturally reverts to a system bias test which drops innane trivia into the FMC's up top in the cockpit. The Captain and FO's weren't trained under the dumbest eff's in the planet at Pinnacle Airlines, so when the question came up "How many fuse plugs are on each tire?" and he answer 4 the plane blew up.
I'm going to hell.
Read this at work and started cracking up!!! So wrong.....and yet funny.
Guess I will see you in hell.....
