Blown tire is a tough one. My previous company had two high speed airports at max gross takeoff weight for blown nose tires. The pilots both felt that it fit under the "aircraft unsafe/unable to fly" definition because it was a very loud bang and rumble just prior to V1. The company felt otherwise and thought they should have taken them into the air. There was significant damage to the underside of the airframe from the tire debris in both cases. Hard to say what I would do in that situation. I agree with the concept of going like you because you're right, it would be easier to stop from a stable approach, but the startle factor might cause an abort reaction like it did with the two pilots it happened to for real.
TP
Tire failure go/no-go always brings this one to mind:
http://forums.jetcareers.com/threads/when-mr-murphy-rides-in-your-jumpseat.91792/
