mrivc211
@AAPalmTree I could see how my last post may be taken as condescending or smart aleck or laughing at you.......trust me when I say it wasn't meant to be.
It's not a issue of being outgunned. This discussion (which I find very interesting) started by debating how the movement of thrust levers could have helped the AF296 pilots. The FO was manually manipulating the thrust. He knew where the thrust levers were. That's where Typhoon pilot was wrong.
I also know (although a Boeing would never go there purposefully) if a Boeing was that close to the a-max or critical AOA with no spool on the engines and the pilot pulled back on the yoke... It would stall. That's where I also think TP is wrong.
TP,
A few things.. There is much more controversy than just the state of the engines. There is missing time on the FDR/CVR in the crash. The black boxes brought to the trial were not the boxes from the accident. I believe there is a lot more to that crash than we know.
It's impossible for me to tell where the thrust was if it was in manual mode. I'm not sure what you mean by there is no question where to move the thrust levers for a go around. There has never been any question where to put them on a go around in any jet I have flown.
I full heartedly agree with you on the feel. I wish airbus had tactial feedback on the side stick and pitch trim.
The airbus is the sixth jet type I have been on (no Boeing). Have you been on the airbus?
Good discussion.
It is a good discussion and I have learned a few things from this. I am aware of the controversy on the FDR/CVR. Sort of a conspiracy theory going on there.
For FBW Airbus I have flown the A330 sim a little, but not in line operations.
What I meant by knowing where the thrust lever position is basically is there are pretty hard detents in the Airbus, correct. I vaguely remember something about the F.O. placing the thrust in the Flex detent and not all the way to TOGA. It just seems to be there is a lot of room for error in and misunderstanding in that design. In a Boeing you get the thrust based on the thrust lever position, never anything different. So there is far less possibility of a mistake being made based on lack of understanding on mode/detent/position of the thrust levers. If you want TOGA or full thrust you just press the TOGA switches or push them full forward.
TP
I am learning things as well. Question for you.. If authothrust is off and the Boeing is in approach mode/phase will thrust levers in idle give you approach or flight idle?
If that was a question: yes, there are hard detents. Not to open a can of worms (and support your case) not selecting/achieving toga has been issues elsewhere as well.
Oh, I like opening cans of worms
How about if one thrust reverser is MELed and not pulled into the reverse thrust detent after touchdown?
TP
If you are talking about TAM... Those guys earned that accident. Who could possibly think it would be wise to leave an engine in the climb detent after landing? The plane is automated... But not that automated.
That would be a ridiculous reason to laugh at somebody for. Now, if you've got a phone clip on your belt........No problem! No offense taken.
I grew up in Seattle and I fly an Airbus... I am probably laughed at behind my back on a regular basis.
Their is nothing fanboi about In-n-out, however. That IS the standard.I see that if I was to have gotten into aviation, I'd have to deal with an Airbus/Boeing fanboi contest as bad as anything you get between Android and iOS.
They're airplanes, guys. You fly them from point a to point b and get paid to do it. Sometimes there's people in the back, sometimes there are boxes in the back.
Ain't no reason to get all "oh yeah, well, the airplane manufacturer I'm a fanboi of is better and if you don't agree you're stupid" about it.
One of the major problems with the Asiana crash is the pilot flying was coming off of an Airbus. He had lost the ability to be aware of tactile cues because he was used to the non-moving thrust levers in the Airbus. He clearly lost, or never had, more airmanship skills than that since he did not even scan his airspeed indication properly.
I could not disagree more in the assertion that a Boeing would have been flown into the trees doing a low pass the same way the A320 was.
Here is what they were attempting to do:
"The Captain would slow the aircraft to its minimum flying speed with maximum angle of attack (nose-up attitude), disable the "Alpha Floor" (the function that would otherwise automatically increase engine thrust when the angle of attack reached 15°) and rely on the First Officer to adjust the engine thrust manually to maintain 100 feet."
The Boeing doesn't have "Alpha Floor" protections so you wouldn't have anything to disable. Nor would you try to do a maximum angle of attack pass relying on automation to prevent a stall. It just wouldn't happen in a Boeing. They might do a low pass at low speed, but it would be flown by pilots using much more conservative techniques. Back when that accident happened the Airbus mantra was basically, "you can pull the stick all the way back and it will never stall". That never has been, nor ever will be the mantra in a Boeing.
Airbus's design philosophy, and resultant decrease in piloting skills, has led to many accidents and AF296 was one of the first in that vain.
Typhoonpilot
I've got lots of hours in both. Boeing builds great airplanes. Airbus builds great airplanes. You can "turn it all off" and be a pilot in either. You can become a slave to automation in either.
Well you're obviously open minded and neutral. None of what you post from this point forward will be given any validity.
I bet he likes FRENCH fries with his AMERICAN burger too.
Crazy guy.
Actually hamburgers are German. Hamburg. Duh!
But then you knew that!![]()
