RDoug
This isn't true, sound's speed isn't constant like light. You would hear the horn, this is the same as the baseball on a plane.
I never said the velocity of sound was a constant. It most assuredly isn't. It varies according to the medium through which it is propagating and the temperature, density, and other factors of the medium itself.
What I said is since sound travels by wave propagation through a medium, it is limited to the medium through which it is traveling. A baseball, being a solid object, is not thus limited. You're attempting to apply Newtonian physics to a fluid dynamics problem.
This is a visual representation of precisely what I mean:
It's an F/A-18 passing through Mach 1. The condensation is developing in the sudden pressure drop in the shock cone developed at the precise moment the aircraft exceeds Mach. And, just as that condensation will never reach the cockpit as long as the aircraft exceeds Mach, neither will the rest of the pressure wave — which just so happens to also be carrying the sound of that aircraft. That's a bit of an oversimplification, but not by much. And if the aircraft continues to accelerate? Then the pressure wave behind it elongates into an even more distinct cone shape than what you see presented here. The longer that cone shape, the further behind the associated "sound" falls behind in ever reaching the cockpit.
