Ya that wasn't really a big issue, it is a similar layout to the PIDP I used in the AF. Plus I'm a little bit of a techie so it really wasn't a problem for me.Are you used to the keyboard yet?
Ya, I am glad as wellI went to C90 from ZAU last October. Certified on the side line (departure/north satellite). Starting arrival training in a few days. It was a bit of a learning curve and like you said, there isn't much room to fix a mistake. But it's been a blast, glad I made the move.
I will, Gary is an FLM here, good guy. I might be opposite of Sean, I don't recognize his name. I'm still learning everyone's names though!Say hi to Sean Q. and Gary S. from their friends at N90! Our loss was C90's gain!
You guys are about to get a girl from ZAU SE (my old stomping grounds) this year, she's good people, was a heckuva great OJTI. Don't know what area they plan to stick her in yet...
I forgot that Gary had switched to "the dark side". Sean went there before Gary, and I believe he's still there. As for your friend, if she's good (and having ZAU in her resume seems to indicate that), then she's probably coming to our area (EWR), as we're the most critically staffed area, and need good, experienced controllers.
Sean Q was on my crew for a while and is a great guy to work with, If Gary got there in late 2008 or early 2009 than I know him too, he was kind of a quiet one.
I retired July 2009 but I remember Gary, took me a little to remember his last name, his nickname was Gay Sailor sort of a play on his name but you are correct he was one of the good guys.
Mind the gap?After this it becomes easier once you grasp the concept of feeder/final. Make gaps, keep gaps, and hit gaps!
That would work too... Make gaps between bases and downwind aircraft by keeping MIT between them (say 7 in trail on both base and downwind). You can make them by using speed control, vectoring, et cetera. Keep the gaps you have and dont let them compress. Finally, put aircraft in the gaps you made. Youll figure it out pretty quickly when you start on the approach wall or whatever M98 calls it.Mind the gap?
Mind the gap?
