Most modern large civil aircraft use an Aircraft Condition Monitoring System (ACMS) to acquire the data for EHM. This captures three types of reports:
The first are snapshots, where the sensor data listed above is captured and collected into a small report. This is carried out during take-off, during climb and once the aircraft is in cruise.
The second type is triggered by unusual engine conditions. Examples might be if an engine exceeded its TGT (Turbine Gas Temperature) limits during a take-off. These reports contain a short time-history of key parameters to enable rapid and effective trouble-shooting of the problem.
The final type is a summary, which is produced at the end of the flight. This captures information such as maximum conditions experienced during the flight, and power reductions selected during take-off and climb.
The Trent 900 is the first engine to be fitted with a dedicated Engine Monitoring Unit as well as the ACMS. This engine-mounted system places a powerful signal processing and analysis capability onto the engine. A fan -mounted EMU is shown below:
This is used to look in more detail at the vibration spectrum, which helps to pick up problems with bearings or rotating components. It also provides a flexible computing platform so new EHM software can be rapidly deployed to detect specific problems.
