We have two big fuel numbers on our release at work.Kind of a silly question I know, but I just wan't to clarify what exactly is included in your min fuel number on the release. Thanks!
The first is "MINTO," which is the minimum amount of fuel that must be on board when the power/thrust levers are advanced for takeoff. MINTO is the FAR minimum fuel required to legally complete the flight. That is, it is enough fuel:
• to fly to the destination airport considering forecast winds blah blah, then
• to fly to the most distant alternate airport to which dispatched if an alternate airport is required, then
• to fly at 45 minutes thereafter at normal cruising speed.
MINTO is, if you didn't already guess, the bare minimum amount of gas to do anything, and I do mean MINIMUM. We hardly ever take off in the Brasilia at MINTO, for many reasons.
The second is "RLSF" or 'release fuel.' Release fuel is MINTO plus holding, contingency, and taxi fuel, dispatcher or Captain add, and so on. Release fuel is reducible at the Captain's discretion by half of the contingency fuel or "I forget" pounds. (We hardly ever, ever do that on this airplane (indeed in almost 2 years on it I don't think I've ever seen it), and most of us consider the release fuel number the minimum required for pushback.)
We also have a breakdown of the fuel figures on the release into the various categories (taxi, enroute burn, holding, contingency, etc.).
Ah yes. MELs that have an impact on performance or fuel consumption will also be included in MINTO.Goes to show each carrier is different. Our minimum takeoff fuel includes burn from point A to point B, alternate fuel, reserve (be it 45 min domestic or 10% plus 30 mins for international), hold, MEL fuel (APU has to run continuously? That goes in MEL fuel), and contingency.
At Eagle, I was up against MIN T/O (as they wrote it) twice. Both times were very unpleasant experiences. One dispatcher was notorious for using planned arrival fuel figures - FOR A TURBOFAN AIRPLANE - similar to those I've seen on the Brasilia. (shakes head)For purposes of definition, minimum fuel is defined by 121.639 or 121.645. If the question is referring to FAR minimum fuels, that is your answer.
Depending on what equipment your company operates had an impact on "company minimum fuel". If you're a CRJ200 or Jungle Jet operator you don't have the luxury of "kiting" fuel.
Ya know, I never thought of MINTO that way. I think I'll start passing that around...seems accurate enough given how it's computed, above, to the pound, as burnoff + alternate + IFR reserve.Enough fuel that you can land safely, but then flame out both engines while taxiing to the gate.![]()
