Autothrust Blue
”…trusting ze process…”
"Buzzsaw 5155 stand by with your minimum fuel declaration; Southwest 2141 Los Angeles Center roger, how would you like a shortcut?"How 'bout direct destination?
Requesting cruise clearance to JFK.
@amorris311 it was into MCI. Very gusty, ice speeds, and right at 75,000 pounds.
We've got a switch!
The climb gradient required to fly the missed as published is 5.5% You must maintain this climb until 10000ft
Provided you turn the correct direction... you don't have to do that 5.5% for long but if you don't you are dead.
Anyway something to keep in mind.
What, your center tank fuel load?![]()
In this case, IFR departure is not authorized from that runway, IIRC.Though I'm not a pilot (yet) I follow these forums often because I'm an aviation fan. Please forgive my ignorance, but I must ask: How is going missed, even right before touch down, any different at all from a plane taking off from the same runway? It seems to me you would have a head start compared to a plane starting it's takeoff roll. If a plane starting it's takeoff roll doesn't have a problem clearing terrain, why would a plane going missed have an issue avoiding terrain when it's already higher and faster?
Can someone explain this to me? Thanks
In all seriousness the E-175 is a bit crazy on landing speeds sometimes due to an extremely conservative automatic minimum airspeed increase after having flown through almost any amount of ice. We'd have gotten the stick shaker at probably 135 knots under those conditions.![]()
I was gonna guess main deck payload, but that'd still be on the low side.What, your center tank fuel load?![]()
Them: "Tell you what. Scratch the flight - I'm calling someone else, I'll never use you guys again, and I'll make sure that everybody knows that your company was the only one that couldn't get into Aspen today."
I've also noticed A330's approach at crazy high pitch attitudes. The difference probably has to do with tailstrike avoidance.
I'm always impressed at the difference in average approach speeds between the A330 and a 777; like 130 kts vs 165 kts.
This airport is one way in one way out. Meaning the direction you takeoff is away from the mountains and the way you land is into the mountains. Going around in Aspen requires a tight turn and back up the valley to get out.Though I'm not a pilot (yet) I follow these forums often because I'm an aviation fan. Please forgive my ignorance, but I must ask: How is going missed, even right before touch down, any different at all from a plane taking off from the same runway? It seems to me you would have a head start compared to a plane starting it's takeoff roll. If a plane starting it's takeoff roll doesn't have a problem clearing terrain, why would a plane going missed have an issue avoiding terrain when it's already higher and faster?
Yep. All of the departure procedures at ASE are off of 33 only.In this case, IFR departure is not authorized from that runway, IIRC.
You don't even know.
