@MikeD
A question was posed on another forum as to why CFR chose to pull the windscreen to access the cockpit instead of cut through the skin. Any particular reason?
A couple of reasons probable:
1. Fire hazard. Cutting with a K-12, especially if there aren't marked "CUT HERE" outlines like many larger aircraft have, make cutting a large hazard if there's spilled fuel, or unknown location of hazards such as hitting an aircraft structural beam with the saw blade (severe sparking and possible destruction of the saw blade), fuel crossfeed lines or center tank lines [in the mid to aft fuselage area], or electrical hazards. [see the 1976 crash of Mercer Airlines DC-6, near KVNY]
2. Access through the windscreen is easier if there's damage or the windscreen can easily pulled or popped, and the crew is right there....its the most direct access to them. The Main cabin door may have been warped so it may have taken some work to get open due to the crash dynamics on the airframe.
3. Cutting, in this situation, can't be done on the cockpit due to how the aircraft is at rest, with the weight of the forward fuselage resting on the top of the cockpit. Some serious cribbing and stabilization would need to be done before attempting this, and thats fairly time consuming.
