ppragman
No pasa nada.
Imagine you're on the ground at an airport with a thin layer of fog. The vis is 1/4 SM, and you know that the ceiling is only 200' thick (because you're psychic, or have a balloon with a camera and an altimeter on it, or whatever, this is a thought experiment bear with me). You're part 91, and the airspace is class G until 1200' AGL. The terrain is non-mountainous. There's no obstacles that require an ODP or anything like that.
Could you depart IFR without a clearance in Class G because by the time you enter controlled airspace at 1200' AGL you're 1000' above the clouds, and because the entire time you were in Class G you were climbing out - which means you're not in violation of 91.177 (except as required for takeoff and landing), then when you become VFR at 1200' you're 1000' above the cloud layer. The only thing I can think of would be the catch-all 91.13 violation if they wanted to get you - but out of curiosity, anyone have any case law?
