How would you get an altimeter settings in IFR lost COMM?
Robyn1993
Since you need to be at a certain altitude to shoot the approach, and you don't want to be below the approach altitudes specially in a mountainous area. How would you get an altimeter settings in IFR lost COMM situation?
I would say that you should use the last one you were given, backed up with a look at the last few destination METARs (a good sanity check).
While airborne...
Find one nearby that transmits on equipment you can receive on, IE a VOR or NDB.
Sent from my iPad using Tapatalk HD
I'm thinking if you can listen to a VOR, or even NDB for that matter, you could listen to the ASOS/ATIS.
This. Problem solved. If you're flying for a long enough time and distance that may not be valid any more chances are very high you have a radar altimeter.
...which you wouldn't be using for this situation anyway. :P
