You think the tower always has you in sight when they clear you to land?
The phrase merely means the runway will be available for your use. Using it is at your discretion.
Flying into Diego Garcia, cleared to land 200 miles out from FL390.
Have seen MDs and DC-9s doing that a few times in my day.
You post made it sound like that info was something new that you hadn't seen; hence my reply. Unless its no longer normal practice.
Our discussion was about backing up on the runway to get all usable space, but then turned to backing out of a gate. NEITHER is recommended here. We can do a turn out (with room).
Besides, why do they call it a 'tug' if it usually pushes?
Once more, the intersection of practicality and the dollar.
The first time I went into ELP I couldn't believe that it wasn't one airport.
My "I learned from that" story was lining up on Biggs instead of ELP one dark night. I caught it thankfully but It taught me how easy it is to do. I think like most risks in aviation, once you get bit or almost get yourself in trouble over something, you develop additional techniques or habit patterns on that particular issue or procedure to keep it from happening again. It doesn't take much distraction or lack of awareness to really screw something up in this business. I've had my share of oopsies over the years but have managed to develop some self defense cross-checks to save me from myself. Now if I could stop trying to drink coffee in turbulence I would have it made.The first time I went into ELP I couldn't believe that it wasn't one airport.
For those who want the crew fired for this incident, what does that accomplish?
A mistake was made by the crew and if you don't allow the complete system to learn from this mistake the mistake is likely to repeat itself. Look at the 'just safety culture' aspect of it. It is also extremely disheartening that the ATC Folks could also be 'fried' over this per military channels. Hopefully cool heads prevail at Atlas and this crew is retrained and the lessons that are learned from this incident permeate throughout the line.
I agree that making this the example from which others can learn is one way to handle this.For those who want the crew fired for this incident, what does that accomplish?
While I'm not advocating the firing of these pilots, if they were to be fired, there is a lesson to be learned by "the complete system" as well.
The lesson being, check twice and maybe three times as you approach an airport because the last crew "screwed the pooch" and are out looking for employment.
I believe either way is acceptable as far as how effective of a learning tool this could become in the future.
Of course everything I state here has my full support AND has been substantiated by my opinion.
It will make people afraid to make honest mistakes. When they make an honest mistake they won't report their mistake and try to cover it up. Under that type of culture, no one will learn.
Asiana's crash resulted in injury/death.So you give the Asiana pilots crap for an honest mistake, but want to give these guys a free pass? I don't get it.
I have to keep clear of this thread, but a mistake that causes injury/death is not a "no harm, no foul" event that might simply result in retraining.This very well could have. So dumb luck is how we determine punitive action?
NTSB just tweeted out that they have opened an investigation into this "incident".
If no metal was bent what would the NTSB investigate?
