Cessnaflyer
Wooooooooooooooooooooooooooooooo
Haha yeah I'd probably rather burn to death than stop in Pasco.That represents a difficult choice for a PIC. Burn to death or go to Pasco. It's a 50/50 TBH...
The CRJ-700 has on bottle for both C3 and C4. Better hope you only get a fire in one.
Had nothing to do with fire and was an idiot CA, trying to make a point.
"Land at the nearest suitable airport" is both an uncompromising instruction and appears with considerable regularity in the airplane's QRH with respect to most fires.
Sooooooo.......what is the story with that?
Engine vibration so they did a inflight shutdown. CA and dispatcher got into a pissing match over ACARS on what was the "nearest suitable airport". CA put the airplane into a aggressive descent to land in Martinsburg WV a airport that we have no charts and zero airline service over any number of airports in the area with AMR service and we have chats for.
Ah, of course. For me, it means the one with the long runway and big firetrucks.What Rocketma99 said. The QRH doesn't do you any good when you're dead. Granted, it'd have to be a very in-extremis situation and it's a very out-of-the-box idea. But its better than being dead, and it's been done successfully before. It's just not something fixed-wing pilots think about. Always better to turn an extremely critical emergency like that into a ground emergency; and off-airport is just one card in your deck. It would be unwise to discard it because of fear of the unknown.
Define "suitable" for me. Query 10 people and you'll get 10 different answers.
And was he sacked, or just re-educated?
Eh, it's a Brasilia. Guy with a hose will suffice.Ah, of course. For me, it means the one with the long runway and big firetrucks.
I'm too busy dicking around with fontconfig to give a proper response to this.
@Derg, why your forum fonts so UGLY on Linux?!
Because Linux, no doubt.Why yo' default font so motha-grabbin' fugly, TRICK?![]()
Rest assured, I'm onboard, and agree with you.And thats cool, as it's kind of subjective when its not really defined. To others, it's X runway length minimum, or availability of maintenance, or whatever. My only point is, fire is nothing to screw around with when it involves the fuselage. MD-80? The engine is on a pod and will probably burn itself off if bad enough. Your Embraer? You get an uncontrollable engine fire on that wing mount, or a fuselage fire of some kind that you can't get out, and the suitable field.....by your own definition......is 15/20/30 minutes away; you going to still try and roll the dice to make that, with fire spreading to places you don't want it to? When you may possibly have a suitable landing site thats not an airport? I sure wouldn't. Turn that air emergency into a ground emergency. If you can land in one piece on a suitable road or something and evac, let the plane burn.
Look at the B-17 that landed in the field successfully after it's onboard fire, landed in one piece even. Your plane could do it too.
http://forums.jetcareers.com/thread...le-accident-1-year-later.147397/#post-1931527
And TACA 110, showing a transport category jet can do it too
http://en.wikipedia.org/wiki/TACA_Flight_110
Is it the answer to any emergency? Of course not, it's very much the exception rather than the rule. But to dismiss it outright as a potential card you can play in an extreme emergency just because "...the QRH says suitable airport...", is one of those times where the checkilist, literal and verbatim, will get you killed. Serious food for thought.
