PhilosopherPilot
I agree that a constant descent rate is better than dive and drive, although if it's going to be close I want some extra time at MDA to look around.
That said, your #3 is one of the more ridiculous things I've read on the internet today. How on earth are you going to hit anything if you're at or above MDA? You have an absolute minimum of 250ft of obstacle clearance, and possibly a whole lot more... depending on lots of things that terps explains. A non precision approach is not scud running.
The whole point is creating an "ILS like" approach. You get down there, if you see it, great. If not, you go. "Taking a look" is what they are trying to avoid.
So you're saying that the risk at 600 feet AGL is the same as at 10,000 feet? Clearly the risk is higher when you are lower, even on an approach path. The longer you are at that lower altitude, the more you are exposed to that increased risk.
There are numerous ways that driving around at MDA is risky. For instance, if you level off and don't advance power, then you don't have much margin for a stall recovery. If you're instrumentation is off, you may be outside of the TERPS protected area, and near obstacles, etc.
I agree that it is generally an acceptable risk to be at MDA, but the idea that it is not risky at all is just not true. The airlines are all about acceptable risk, and minimizing the risks as much as practical. So if you can make a non-precision, which aren't as common as ILS procedures in airline flying, more like an ILS, it brings the risks down, which is why many have moved to that type of procedure.
It's really not easy to explain how airlines think about safety on a forum typing on an iPhone! It's not how most pilots think about safety, though most airlines are trying to educate their pilot groups about contemporary safety, and safety management.
Basically the safety = reducing risk to an acceptable level, and each airline decides for itself what risks they think are acceptable. Their procedures reflect those management decisions.
Clear as mud?
