ATC Jesus
Savior to the Medivacs
Preach it! Some of the posts from our west coast brethren imply that all medevacs should get direct all the time.
They should! Nobody is going to die if those air carriers are stopped for a few minutes, or vectored. Nobody dies if you miss your connecting flight, or get to the airport 10 minutes late. You don't cut 10 minutes off a medevac flight's route, and the potential is certainly there.
Those aircraft would certainly be stopped for an emergency, and the coordination between the 7 or 8 sectors would magically happen. In fact, it would be overly coordinated between the sectors, supe-to-supe, between facilities, etc. Nobody would ever think twice about it. A medevac is one step down on the priority handling chain, it's a life critical flight (that's how they are defined by the FAA), yet a supe wouldn't lift a finger to coordinate that aircraft being direct. Nobody would coordinate sector-to-sector, because there is no way air carriers and business jets are going to be moved to accommodate this life critical flight. No way are departures going to be stopped. No way are air carriers going to be vectored.
Maybe the mentality isn't just a west coast thing.
