How do you know? Lets say for arguments sake they were traveling at 130mph. At that rate they are doing roughly 200 ft/sec. That would mean they were about 2 1/4 miles out if they were following a 3 degree glide would put them at above 600 ft AGL. I don't know if they are part of the stable at 500 club or not but it would be perfectly SOP if they were. I know that is a little too much speculative but it makes for a good argument. As someone said earlier in the thread there seems to be an issue with them and shorter runways. Maybe being stable at 1000 could help but then again it's LGA. Unless you're landing on 22 or 4 there is no shot in hell you are "stable" in that parameter. It will be interesting once the final come out on this.That being said, since the investigators said the flaps were in motion 56 seconds prior to landing, then they certainly weren't configured early.
Stabilized approach means that you are in your final landing configuration at a set altitude above the touch down zone. At my company that is 1000ft AGL. Some companies are 500ft. That being said a minute before touchdown is not necessarily considered unstable so long as you fit the pre described criteria. Is that clear as mud?
LGA is not the bar standard for configuration. The runway in which they landed though is a straight in so my argument loses steam. If they were doing the circle to 13 or the expressway to 31 I could see them use that as an issue. Landing 4 though there shouldn't be any reason for instability and continue the approach.Got it. Being configured at a set altitude makes way more sense to me than being configured at a set time or distance. Is this is standard descent profile into LGA? Seems like even at 60 seconds, they would still have some room for configuration.
Those videos are cray cray. It may be too early to tell, but many YouTube reporters point to the fact only half the amount of male genitalia normally found in a flight deck was present at the time of the landing.
The Brasilia is to be stabilized (final flaps, gear down, checklist done, on speed, on a manageable glidepath, spooled up) at 500' AGL; the Arr Jay is 1000' I believe.So, quick question for the folks out there flying 121... based on what I'm seeing here in this thread and MSM reports, making any configuration change (another notch of flaps, for example) even 56 seconds away from touchdown is considered an unstable approach? Just getting clarification. I could understand it being considered unstable if, say, you didn't have gear or ANY flaps down. But I wouldn't think that putting in that final notch of flaps a minute away from touchdown would be that big of a deal. Thanks in advance for the edumacation.
For the lulz:
SurferLucas said:Y'all that fly the 73, I have a question for you...is Flaps 40 a standard landing config? In all my times riding the JS on the 73 (various operators), it seems that 30 deg flaps is the SOP for the 737 (30-30-Green light).
Can't say I ever recall seeing a Flaps 40 landing in a 737.
Yea but if you cross over 13/31 you aren't doing it right. Duhhh everyone knows that.Standard is flaps 30 autobrakes 3
I looked at the numbers today, with dry conditions, the difference between flaps 30 and 40 with various autobrake settings is a few hundred feet, at most.
amorris311 said:Yea but if you cross over 13/31 you aren't doing it right. Duhhh everyone knows that.![]()
I think it was NWA who put a bolt in the flap lever tracks and prohibited people from landing the 727 at Flaps 40 a ways back. Difference was "meh."Standard is flaps 30 autobrakes 3 at my place. As a side note (and to give a little background of the SWA culture) we have lower flap speed limits than the hard Boeing limits. SWA, from what I was told does not have those lower speed limits. Those lower speed limits help with wear and tear mechanically and helps with more stabilized approaches.
When you land on runway 4 you don't cross over 13/31. It's a poor attempt at a joke.Huh?
Autothrust Blue said:I think it was NWA who put a bolt in the flap lever tracks and prohibited people from landing the 727 at Flaps 40 a ways back. Difference was "meh."
