SFO 07/037 (KSFO A1316/13) SFO NAV ILS RWY 28L LLZ/DME OTS WEF 1307072000-1307072359
Cherokee_Troll, I haven't seen any crucifixion in either words or implication from Seggy. He's merely provided data. That data (if accurate) could indicate a whole host of possible reasons for the crash, and many of them have nothing to do with crucifying the crew.
As usual, you're just looking to stir up trouble.
You're welcome!!Thank you.
I blame Paula Deen!!!
Thanks for your useless post that didn't contribute in any way.Cherokee_Troll, I haven't seen any crucifixion in either words or implication from Seggy. He's merely provided data. That data (if accurate) could indicate a whole host of possible reasons for the crash, and many of them have nothing to do with crucifying the crew.
Butter prevents hull losses, FYI!!they needed more butter
The auto throttle clutch on the 777 has a very low friction level. If you rest your hand on the throttles the weight of the hand overrides them. It doesn't sound like much but you'd be surprised how many times in training and flight operations someone gets into airspeed/pitch problems due to this. The MD-11 auto throttle clutch was a better design.
FYI, what he is saying is also true on other Boeings.From a 777 e-friend of many years:
If this happens after the accident, it's customary in busy towers to let everyone know a go-around is in progress. (Observed at Vegas and LAX.)Interesting in that ATC recording someone yells "Go Around" several times.. It's kind of blocked by the cessna, though not at all his fault. I wonder if that was the UAL 885 crew watching this from the end of the runway...?
The 727 said, "Give me what ya got for a pork chop!!FYI, what he is saying is also true on other Boeings.
So who would like to start the list on potential causes for a 1320 fpm descent rate at 600' AGL followed by a 109 knot ground speed at 100' AGL?
< Disclaimer: I've seen enough Flight Aware data to not trust the numbers. Sometimes they're pretty accurate, other times not so much. >
