ASpilot2be
Qbicle seat warmer
Oh, I don't doubt the strength of webbed material. But... MRAPs are crazy heavy. Between ~14 and ~26 tons, depending on their class and how they are outfitted. The effective holding power of the tie downs will be affected by the angle that they are attached to the load and the floor. Those were some pretty extreme angles in the pictures from that forum. The pictures I've seen of MRAPS tied down in military aircraft by military personnel show some pretty serious chains, and comparatively low angles between the load and the floor. In addition, the metal clasps at the end of those straps looked awfully dinky for a load that size, where as the chains end in a rather beefy turnbuckle. That, of course, might have a lot to do with the type of mounts available on a BCF.
Getting super deep into speculation here, of course, but again... it gets me thinking about how (or if!) I secure loads when I get back to flying, and I don't even fly cargo for a living.
Pardon me while I run out to get some chains for my flight bag.![]()
The only difference between the bcf and the freighter model is where you can put cargo. Other than that the decks are Identical.
). Has there ever been an aircraft out there with a variable center of lift, i.e., movable wing root?
