Xcaliber
El Chupacabra
http://www.avweb.com/avwebbiz/news/BizAv_Affected_By_Delays_208573-1.html
I'm curious about this. I spent about 4 years going around the country in GA aircraft. One of the first things I learned was that under 91, you have a lot more options when it comes to "getting out" than under 121, and a lot of times, you have to use them. According to the article, it says "ATC was not accepting any departures over GVE or DAILY." So why not file another route that doesn't utilize those fixes? It's not very often that ATC offers "optional routing" anyways, you usually have to figure it out yourself. Maybe go VFR until past said fixes? Pick a TEC route until out of that airspace?
I realize it's a management company, and therefore probably 135 and more restrictive. But even still, you should have more tricks up your sleeves than to just cancel the flight.
Then again, maybe ATC was being ornery and wasn't letting them do anything. I don't know. As I said, I'm curious to figure out what happened here.
April 23, 2013
BizAv Affected By ATC Delays
By Russ Niles, Editor-in-Chief
Although airline flight delays due to sequester measures have grabbed the headlines, business aviation is also being affected by reduced staffing levels at air traffic control facilities. An aircraft management company on the East Coast told AVweb that a planned flight from the Baltimore area to South Carolina was scrubbed because air traffic control problems effectively ground stopped it. "The pilot was told that ATC was not accepting any departures over GVE or DAILY," a representative of the company told AVweb. "No estimate of when departures would be available was given, and no optional routing was offered." Meanwhile Dallas/Fort Worth Airport is the latest to report major traffic headaches, according to the National Air Traffic Controllers Association.
In a bulletin sent to the media, NATCA said that as of late morning arrivals at DFW were delayed by 30 minutes and they were increasing. A ground stop was in effect at Dulles and a ground delay was affecting flights at Reagan National. LAX was experiencing its third straight day of delays. Ironically, to cope with the situation, some controllers are being asked to work overtime at time and a half, thereby negating some of the cost savings of the furloughs.
