flying a passenger jet with pressurization switched off
J777Fly
Can you legally fly a passenger jet with its pressurization system switched off with revenue passengers, if the flight is short (20 minute leg) and nevers reaches above 10000 feet?
I've flown (with revenue in the back) MCI-CLT at 8000 feet with no pressurization. It was a) a nice day with no weather concerns, b) warm out, c) a mostly empty flight and d) something I would probably not do again.
How did you have enough fuel for that?
I figured that but I guess I meant to ask how much did you have ad burn for that trip?
It was a while ago. I think it was just north of 9,000 pounds. We do all kinds of stupid long distance, low altitude, high drag flights. We had a plane with the gear locked down on it doing CLT-Florida turns a few weeks ago.
I just happened to check out the 767 MEL for both packs inop... Speed limit is M0.40 (yuck), and the MEL shows a potential cabin temperature for climb/descent of 102F (114F in the cockpit!) if the ground temperature is 86F and maintains ISA up to 10,000'. No thanks!
It's comforting to know that it's not just is doing crap like that.
I'm waiting to hear about the first RJ operator that pins the gear for short flights a la TSA pinning their reversers for "cost savings". I mean, at some point, it's got to be cheaper to keep the gear down rather than put another cycle on them!
Did it at Eagle fairly often. Would use those deferred airplanes for MKE, SBN, MSN, BMI, etc out of ORD.
I doubt it. Gear cycles have to be cheaper than the extra gas you burn dragging that thing along underneath you, even for 20 minute flights.
