Why I haven't been on here too much
Roger Roger
Bottom of the list
If anything from the automotive world transfers to these things, those piston rings let go in a bad way! :eek:
Nah, just 34 years and a couple thousand hours of use.
trafficinsight and Douglas it's an O320 out of the TriPacer. My co-owner is buying me out and I'm redoing the engine before I fly it down to Nevada. Going to send the parts out for inspection but put it all together myself.
Quick update: crank is done, after 2500ish hours and 57 years they ground the mains .003 under and kept the rod journals standard. Not too shabby. Also got the AD inspections on the inside of the front end of the crank and the gear attach area on the rear done. Also a bunch of the other parts are done, and the case has been sent off. So I should be ready to start putting stuff together pretty soon.
The Ad on the hub, is that Lycoming SB505 ?
Otherwise sounds like a nice & clean overhaul.
Looks awesome man. Post more pics! :)
Got a big pile of parts today! Crankshaft, case, accessory case, camshaft (new), bearings, etc. will hopefully start assembling this weekend and post some pitchers then.
Just got done wrestling the case back apart after checking main bearing clearances. That was a hassle but had to be done.
Major argh today. Evidently either the cam is too big or when they overhauled the case they bored the cam bearings too small as I got the case all put together and then found that the cam wouldn't turn. Argh.
Sounds unlikely that they bored it to small. It's been bored oversize. Probably gave you the wrong cam bearings. Did they tell you what size over they went with the case, if they did at all?
