Rocketman99
Frozen Guppy Manipulator
What's Bombardier's procedure for a dual failure?
You have just about the rest of your life to figure it out.
This is good to know, too.The 200 has speed controllers on it. As long as they are working (and I've only seen one MELed once or twice in 8 years), they should prevent the engine from overspeeding and the ITT getting away from you. I've RADAR powered the plane twice during honest to god 40+ knot losses at 200 and 400 feet and both times, although we did get red flashing alerts on both engines gauge sets they did not melt and I think all 4 engines passed an inspection after we landed.
Can someone enlighten a piston guy as to all of this? Do the igniters kick on because there's reduced airflow going into the engine? Does having the igniters on too long with not enough airflow make the thing heat up enough to do this kind of damage?
Gracias. I don't know too much about that turbine wizardry.
Unless you know the details or the individual involved in question, you might not want to throw too many stones please.. There is a good chance that you know may not know many details..
Again it's all rumors but from what I'm hearing the flameout was caused by the stick pusher activation. I'm not sure if on the CRJ the ignitors turn on if the pusher activates.
I honestly have to get in the books and see what it does on our 601. From training when we're doing stalls we have the ignitors on as a pre-maneuver check so I can't remember.
Edit: I just looked it up and it's the same on the 601.
Evidently, neither did the PSA pilot dudes.
Flight Compartment checklist much?![]()
Not gonna lie, I may or may not have forgotten it does that as well...Si me gusta
What do you fly? The Dash has ignitors on it too, and they come on under certain conditions as well.This is good to know, too.
I'm just a turboprop punk![]()
We have a procedure in the 757.
Axe me why we have that!
One time, at band camp... or on departure out of SNA many years ago... (wasn't me!)
The Delta 767-200 on climbout from LAX, relatively low altitude over the water after taking off to the west. Got REAL quiet. They moved the EEC switches (or whatever they are called on the CF6-80A, don't remember) to the overhead panel after that one!
That was a LOOOOOOOOOONG time ago. To think they were mainline pilots just scares me.The Delta 767-200 on climbout from LAX, relatively low altitude over the water after taking off to the west. Got REAL quiet. They moved the EEC switches (or whatever they are called on the CF6-80A, don't remember) to the overhead panel after that one!
