GolfChuck
Trustworthy Source
In a true lost comms I would fly to TTT and begin the JPOOL4, assuming of course that I am IMC
Regarding the obstruction as mentioned above, I don't see the similarity. Regardless of clearance I will never be cleared to fly through an obstruction, i could be cleared through a TFR
You've never been put on a heading that, if you went nordo and continued ad infinitum that your flight would never be in danger? What if you ran out of fuel?
From the AIM:
6-4-1. Two‐way Radio Communications Failure
a. It is virtually impossible to provide regulations and procedures applicable to all possible situations associated with two‐way radio communications failure. During two‐way radio communications failure, when confronted by a situation not covered in the regulation, pilots are expected to exercise good judgment in whatever action they elect to take. Should the situation so dictate they should not be reluctant to use the emergency action contained in 14 CFR Section 91.3(b).
b. Whether two‐way communications failure constitutes an emergency depends on the circumstances, and in any event, it is a determination made by the pilot. 14 CFR Section 91.3(b) authorizes a pilot to deviate from any rule in Subparts A and B to the extent required to meet an emergency.
c. In the event of two‐way radio communications failure, ATC service will be provided on the basis that the pilot is operating in accordance with 14 CFR Section 91.185. A pilot experiencing two‐way communications failure should (unless emergency authority is exercised) comply with 14 CFR Section 91.185 quoted below:
1. General. Unless otherwise authorized by ATC, each pilot who has two‐way radio communications failure when operating under IFR must comply with the rules of this section.
2. VFR conditions. If the failure occurs in VFR conditions, or if VFR conditions are encountered after the failure, each pilot must continue the flight under VFR and land as soon as practicable.
NOTE-
This procedure also applies when two‐way radio failure occurs while operating in Class A airspace. The primary objective of this provision in 14 CFR Section 91.185 is to preclude extended IFR operation by these aircraft within the ATC system. Pilots should recognize that operation under these conditions may unnecessarily as well as adversely affect other users of the airspace, since ATC may be required to reroute or delay other users in order to protect the failure aircraft. However, it is not intended that the requirement to “land as soon as practicable” be construed to mean “as soon as possible.” Pilots retain the prerogative of exercising their best judgment and are not required to land at an unauthorized airport, at an airport unsuitable for the type of aircraft flown, or to land only minutes short of their intended destination.
3. IFR conditions. If the failure occurs in IFR conditions, or if subparagraph 2 above cannot be complied with, each pilot must continue the flight according to the following:
(a) Route.
(1) By the route assigned in the last ATC clearance received;
(2) If being radar vectored, by the direct route from the point of radio failure to the fix, route, or airway specified in the vector clearance;
(3) In the absence of an assigned route, by the route that ATC has advised may be expected in a further clearance; or
(4) In the absence of an assigned route or a route that ATC has advised may be expected in a further clearance by the route filed in the flight plan.
(b) Altitude. At the HIGHEST of the following altitudes or flight levels FOR THE ROUTE SEGMENT BEING FLOWN:
(1) The altitude or flight level assigned in the last ATC clearance received;
(2) The minimum altitude (converted, if appropriate, to minimum flight level as prescribed in 14 CFR Section 91.121(c)) for IFR operations; or
(3) The altitude or flight level ATC has advised may be expected in a further clearance.
It may be ATCs job to keep you clear of airspace and obstructions, but that does not mean that you won't be directed in the direction of a mountain, active warning area, or TFR with the intention of being turned before violation of physics or airspace occur.
