TKS is the shiz. ANY severity of ice(going by the rate of accumulation definitions) just will not stick to the wings or props on max flow. You're usually alright unless you run out, or the cowling and spinner just get absolutely douched in ice.
Shady freight dog tip: try using it as a de-ice instead of an anti-ice system in safe conditions(warm air below or VMC above) to see how it responds. This worked great on the 210, OK on the Baron. A Cirrus might cope, but I'm thinking the sharper leading edges may not respond well to this technique. You might try it out though. You use A LOT less fluid. Again, do it in conditions as if you were a non-fiki airplane. Coming from Flight Express(TKS equipped 210s and Barons), I hate hate HATE boots!
