Everybody seems to be overlooking the fact that there is more than one reason to abort a takeoff. Catastrophic engine failure is, in my opinion, the easiest scenario when it comes to aborting. It really doesn't take any decision making as you will know what is going on. It is also directly addressed in the definition of V1, "minimum speed in the takeoff, following a failure of the critical engine at VEF , at which the pilot can continue the takeoff and achieve the required height above the takeoff surface within the takeoff distance." Because of this definition, we all associate V1 with engine failure and we know how we would react. Engine fails before V1 and we stop, after and we abort. Easy! Well, easy in discussion.
There are also a handful of other reasons that may require you to stop. The decision to abort for these other reasons may not be as cut and dry and it is that decision making process that was taken in to account while deciding to call V1 at V1-5 knots. I didn't come up with that policy, but as a pilot at that particular company, I did agree with it. That company operated a plane that was very overpowered. Acceleration was insanely quick.
Let's say at a few knots before V1, there is suddenly a flashing light in your face. Do you abort? I would assume that many people reading this would say "I have no idea." Why? Because the light alone doesn't tell you much other than something out of the normal is going. So now you have to look down (or listen for PNF). So you look down and read the message. Your brain then has to comprehend what that little bit of information actually means and you have to react to it. Let's say that you make the decision to abort. How far above V1 do you think you are after that little scenario played out? I'd be willing to bet that you are at least a few knots above by the time you pull power or apply brakes.
My point is that, this isn't as cut and dry as some people would like to think. Every takeoff is different and things like weight, runway length, what is past the runway, etc should all come in to play every time you line up.
Wow...FAs are trained not to bother the front during sterile unless its an emergency. They even go over the types of emergencies that warrant a call up front during sterile and most involve smoke, fire or parts falling off the airplane. A pax in the lav on final is more of a minor inconvenience then a real emergency. Its possible that the pax may be having a medical emergency in the lav so landing right away would be the best option. Man, there are some whack ass stories of FAs calling the cockpit during sterile. One I heard at XJT was an FA calling the front at minimums to ask the captain (female captain) if she had any tampons she could spare.
I think I finally have an answer for why we call V1 in the Dash before Vr on a 10000 foot runway. Thanks Steve.You know, the more I think about it the more I disagree with calling V1 5 knots early. While it might be advantageous for an aborted take-off situation, I'm not sure I'd want to be the guy test flying an airplane where we decide to continue the take-off when an engine fails PRIOR to Vef (see definition above).
Well often times in the the Q200 our v1 speed will be in the mid 80's range while rotation isn't until the upper 90's. I never knew that V1 meant anything other than the speed at which you could abort before and be able to bring the aircraft to a stop safely before the end of the runway. Apparently so did everyone in the training department I have asked. My biggest question with it was because you can clearly bring a Dash to a stop on almost any runway over 5000 feet even if you were at rotation speed. And I knew that the ERJ's I commute back and forth from work on usualy have V1 and VR as the same speed when departing EWR so I always questioned why ours was so slow. I had no idea there was more to V1 than that and Steve pasted the actual definitions up. I guess by the definition of being able to fly after V1, having a lower V1 is actually a good thing in an aircraft like the dash.
Just pointing out that I had no idea, and Steve shed some light on a question I have had for quite some time.
This is why our company policy is to brief that we will abort for any abnormality up to V1. We don't try to differentiate between what flashing lights mean what while accelerating down the runway, we keep it simple. Anything wrong, abort. (Remember that we are in small corporate jets, typically operating on runways with PLENTY of room to stop in case of a high speed abort. We stress to our captains that they retain the PIC authority to modify the abort criteria if the runway is *short*, and in those cases many will choose to add the "after 80 knots we'll abort only for engine failure, fire, loss of directional control" or similar kind of caveats. I'm sure airliners are a different kettle of fish entirely.)
Quick question... does V1 in aircraft so equipped take into account the use of thrust reverse or anti-lock?
Good to know, thanks. Now that you phrase it that way, I do remember the mention of using wheel brakes only on the emergency abort cert videos for the 777 and 380.For certification purposes, no.
I suppose I'm a little bit leery of v1-The-Idea, myself. The Rules aren't set up to accept a minor accident as a possibility, but I'm sure as hell prepared to accept a minor accident, loss of license, and loss of career to avoid becoming a scattering of parts in a flaming hole. Every page of your performance data was written using a brand new airplane with near zero timed engines and a couple of test pilots who knew what was going to happen. And yes, sure, there's some "fudge factor" built in, but it's hard to calculate that when the engine quits at v1+5 on that last leg and your head is already at home drinking a cold one. Certainly it's a useful guideline.
PS. Just kidding, FAA, I obviously fly the aircraft in strict accordance with the POH. I was just testing these youngsters for any vestiges of free-thinking.
The fudge factor you speak of is the net performance, 2.5%climb gradient vs 2.8, or 40 ft per mile.
(I know it's a sim, but when we do max perf. APG departures at KASE, KEGE, KPDX ect, the pilots always very the apg numbers. )
Yes, thank you.
Heh. *shrug*. I've done Aspen and Eagle (and, say, Durango) in both the sim and real life, and let's just say the reality of the situation, particularly at Aspen, is not always quite the same as the sim when it's your ass in the seat and your name on the paperwork. The book says you can do it under 135 (just, of course) and you wind up rotating a few hundred feet from the end with radar power...that's a situation where I can see aborting after V1 for an engine failure.
