Please explain how this would cause a stall. I've not heard of this....just curious, at what power setting was this? I also know that on caravans they can compressor stall if you leave the ground heat on, but they shouldnt be stalling at anywhere near cruise power settings.
I know there are a LOT of PT6s out there but in the Caravan with everything working correctly (no broken lines, parts, etc) this will not cause a compressor stall. I talking ground operations (idle) going to a takeoff torque setting.Ughhh, I've had a few to drink, and only had this explained to me once, so I apologize. But something to do with the bleed valves being closed with the heat on, and this too much air being forced through the compressor.
Once again, take the explanation with a grain of salt. I'm sure someone can explain it more accurately.
