Diesel 182
It was the 172 and they never produced it since thielert went under, the numbers on that one weren't great, this one seems okay, useful load will probably suck though
Sent from 1865 by telegraph....
supposed to be 15lbs different with the range of the diesel much higher.
From the article -
The Turbo 182 NXT will have a seating capacity for four and feature the Garmin G1000 avionics suite with engine diagnostics display on the PFD and MFD. Fuel capacity will be 87 gallons, with an estimated useful load of 1,030 pounds. Total weight difference between the diesel and avgas versions of the 182 is expected to be only 15 pounds, Cessna said, thanks to the additoon of a composite prop and other weight-saving changes.​
It does look to be about 70k more expensive than the current T182. That's a LOT of gas.
Outside the US seems to be the biggest market for oil burners.
This is likely the way of the future. I know several companies are coming up with avgas replacements, but I'd be more confident in seeing STC's for diesel engines becoming common.
Electric airplanes are.... well nevermind.
The company making this engine has an STC for the 182 already.
Cheaper I get, but at the 182's level I doubt you'll have trouble finding 100LL, and if you do you're going to the wrong airports ;)
1030 pound useful load it looks like, full fuel would leave you 447 pounds... so yeah, seems okay for a restart Cessna. At least at 11gph you can leave out fuel like the airliners do :P
To put in perspective, current fuel Prices at Biggin Hill, a GA airport near London, are 1.93GBP per litre of 100LL and 0.69GBP per litre of Jet-A1. Yes, that's less than half the price.
It is sad these engines can have a huge impact on aircraft operation price and range, and yet there aren't more engine manufacturers trying to build diesels for GA.
I think this is a great step in the right direction and Cessna thinks so too. Did everyone notice in the article is says that the gas engines will not be offered anymore. So looks like if you want a 182 it will be diesel.
Death to 100LL.... long live Diesel!
I'd run mine on leftover donut fryer grease, like all those metro-pseudo-hippies driving around 1980's diesel Mercedes.... it'd make everyone around the airport hungry all the time and then I'd open a donut shop across the street and get rich feeding their cravings.
No they said there would be no more gas powered turbo 182... since the diesel is (and has to be) tubocharged. You can still get the IO-540.
That's the new auto fuel STC. Grease STC!!!!
I think the real question is.... since it's buring Jet A, can I log turbine time? Does it count as a JEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET so I can get my jet time up for when Delta/United/SWA/NASA calls?
