PT6 compressor stalls
just curious, at what power setting was this? I also know that on caravans they can compressor stall if you leave the ground heat on, but they shouldnt be stalling at anywhere near cruise power settings.
This deal with the bleed valve sticking is during a power reduction. At lower N1s, the compressor sucks in more air than the engine can use, right? So this valve is open to dump the excess. At higher N1's the supply/demand of air is more efficient, so P3 air closes it because the pressure of the P2.5 air is less than the P3.
If you make a power reduction that would require the valve to open and it doesn't (ie P2.5 air is escaping around the valve and not providing resistence to P3), then the compressor kinda gets clogged and backed up with air which upsets the smooth flow of air into the combustion chamber. Fuel keeps flowing plus no air gives you too much fuel when the air arrives and ya get some vibrations (not good ones) , surges, and crazy temps.
Power settings IIRC were 85% during the run up. Never did it during the start sequence, but would do it during flight in a power reduction around 1500Tq. I never could get it to duplicate with MX or they couldn't do it also. Until today with another pilot it went ape #$%^ . For some reason I remember in training is to "lightly malletize the bleed valve with end of screw driver".
When you shut down a PT6A-41 or -42 (like on a KA200) will - should - the Compressor Bleed Valves stay open? (They should be open at the low power settings prior to engine shutdown, right?) Or, at shutdown, do they automatically spring closed, then re-open again at the next engine start-up?
The compressor bleed valves operate by differential pressure alone. At low N1, P2.5 air pressure is greater than the P3 air pressure, and the valve is open.
Yup, got that. I'm wondering, where do they "rest", with NO N1, no P3, no P2.5 ........ i.e. with the engine shut down? (Assuming no malfunctions)
