I don`t know what they were thinking when they designed it, the one for the 206H is so bad.....the bottom of door opening in the pod has cut outs to accomodate the Hinges bolts when closed, that makes the whole bottom portion so flimsy, you are literally able to break the frame corners wiht your hands, ours lasted couple flight of stuffing things in the pod and broke off!! The pod door can`t be totally opened, becasue when you are done loading 300 lbs in it it makes it impossible to close, so you have to keep the door at and anlgle, either holding it with your hand or put a stone or something on the bottom. The front top part of the pod doesn`t seal to the fuselage, but the hole is way to big for the nose gear brackets, when it rains the pod fills with water, they only made two drain holes the size of a needle and the whole inside floor is totally flat, it does not have this little frames that go across to keep stuff in their stations.....bad product
