SteveCostello
My member is well-known.
Oops. So... whatcha think? Will that buff out?
How'd you get a video of my last landing? I thought I did a pretty good job, no?
Only the finest graduate from the Harvard of aviation.I was very impressed that you managed to land in such a way as to bend, but not break, the fuselage. That takes a very careful touch. Very fine technique, sir.
This is why you never drop the nose when landing haha.
Wasn't as simple as that. Landed at NRT around the same time. Probably just before the aircraft concerned.
Winds observed at 1000 ft agl were 240/58-72 kts, dropping down to 230/48 kts steady at 500 ft. And then there was a +/- 15 kts WS reported. On my observation it was more like +/- 20 kts windshear!
And the turbulence was huge. Moderate to moderate/severe turbulence REPORTED by 4 airplane before me from 500 ft to touchdown. I observed Moderate/Severe all the way down from 500 ft to touchdown.
And BTW the winds reported on ground were 220 to 250 at 28 gusting 44 kts. That's a direct crosswind for the runway in use-16R.
And the winds were spot on!
Airport should have been temporarily closed.
Damn. Was this particular airplane a write-off?
I would hope so. Once a monocoque construction has been damaged it can't be fixed back to full strength.Yeah. I saw that in the video. I'm no A&P, but I assume that once you wrinkle an airframe like that, it's pretty much done. Is that a correct assumption?
Pretty much. De-rotation can be ridiculously hard on an airframe. I seem to remember another handful of 763s have been written off in this manner.Yeah. I saw that in the video. I'm no A&P, but I assume that once you wrinkle an airframe like that, it's pretty much done. Is that a correct assumption?
DARs will sign anything off.![]()
Not necessarily true. This one is flying again.
The bent 73, however... that will have damage all the way around the circumference of the airframe. You'd have to chop it and sew it back together with an entirely new section. I would think it'd be easier/cheaper just to take off all the good parts and scrap the rest on a 737.
