Highest Flight Level?
You should get some kind of medal just for that. I clawed my way to 250 a couple of times in the three bladers, and I think maybe 270 in a Marquise once just to see if I could do it. I'm pretty sure that one would have fallen out of the sky before it hit 290.
It was cool to be up there, Just two of us in the Marquise. Dash 10's are the way to go man.
Most turboprops being certified to only go to 250 has nothing to do with the engines but the pressurization system, just like the DASH. The engines can go much higher but the airframe isn't designed for the pressure.
You will have to ask some of the Jet guys but the Dash is only certified for a pressure differential of 5.95PSI max. Normal is 5.5, I'd imagine a lot of the RJ's are in the 7.5 or 8 range, and larger Boeing aircraft being ever more.
Interesting. The CASA is not pressurized, so that is one less thing to worry about for us. :)
I'm an A/P, we have to test the safety valve. If you've had a recent cold or sinus problems or have trouble adjusting your ear pressure stay out of the airplane. Interesting to watch the skin "pillow" and the cabin windows bulge from the outside. At FL45 in a G-III in the cabin hearing creaking noises is a little disconcerting.
If you really want to have fun take a 30 series LR into the high FLs (for troubleshooting) and enjoy emergency pressurization.
250 in the 'Hundo. Max service, but flys well up there. Nothing like hand flying all the way. 260 in a Meridian with CK.
I thought the 250 limit was because of the lack of O2 masks in the back for the pax?
IIRC the Dash has something like a 7000-8000 ft cabin at 250.
