@Everyone , Before it flames up, I meant reversers. I was looking through my king air manual and my mind was on beta. My apologies, whip me down good.
However, yes, the DC9 is different because the engines are up higher and they aren't "thrust diffusers." Most jet engines you're basically just blowing the bypass air out the sides. If it goes forward, so much the better. It dramatically reduces your forward thrust, helps to kill lift and therefore combined really help the brakes work better. Even with a prop aircraft, beta doesn't necessarily cause reverse thrust, just nil thrust. If stopped, yes they can go backwards in certain circumstances. Not every aircraft can do it because of the gear. If the main gear are too far forward, going reverse will just cause a tail stand. Due to the DC9 bucket reversers, high mounting and heavy nose, it can go backwards at the cost of significant FOD that can damage the aircraft and ground crew. I know the C130 can if OK'd, but it causes damage and can damage the engine due to reduced intake air and higher EGT.
I hope that makes up for saying BETA when I was too tired to know. I have to start realizing I shouldn't type late.
