Roger Roger
Bottom of the list
I dig it.The one I was once taught was the 4 Ms
Mixture
Mags
Master
Miller Time
Mixture
Mags
Master
Miller Time
My question is when are these people doing the "read-do" type of checklist usage? Staring down a the checklist can cause a hazard while in the air. I understand a new pilot wont be able to do a "do-verify" type of checklist usage but if they memorize the checklist (which in a C-172 isn't bad) then they can create their own flow relatively quickly. I would also tell them to hanger fly when they can as it is free and they will transition to a "do-verify" system quite easily.
If they are career students the transition to an airline would be much easier.
Stop whining, ranting and getting headaches because other people use a different procedure than you do.
Yes, when I get in the airplane with an experienced pilot who hasn't developed flows, I wonder how come. If it's a training flight (like a FR), I will even suggest that he or she consider learning flows. But, so long as the pilot isn't doing something unsafe, I don't get worked up over techniques just because they are not mine.
No need. I forgot the smiley on my comment. It was meant to be tongue-firmly-in-cheek.Ok please let clarify my comment.
Im even ok with a memory "LCGUMPS", just as long as they do it.
Well thats a good point. For most small airplanes, GUMPS gets the job done. Most airplanes will make it onto the ground ok as long as we get the gear down anyways...I wonder sometimes if we pilots overcomplicate the process.
We do tend to over-complicate but the flip side is the development of bad habits.Well thats a good point. For most small airplanes, GUMPS gets the job done. Most airplanes will make it onto the ground ok as long as we get the gear down anyways...I wonder sometimes if we pilots overcomplicate the process.
Bottom line - this is what it's all about.It's my firm belief that doing things the same way, every time is the key to doing things safety and only modifying your procedure when conditions dictate. Or, "I'm at this point in space, I should do X, is that prudent? Yes/No, do X/don't do X - do Y."
This.Not a CFI but that's never stopped me before.
I personally do-verify for everything with a notable exception. If its an abnormal procedure I read-and-do after any associated memory items are completed. Since I don't do those that often, I figure its super important not to screw it up, and given that order usually counts with what you do after a memory item, or after something abnormal makes you bust out the checklist, its important to be cautious about which switches you start throwing. That's just me though, initially at FSI they wanted us single pilot guys to read and do. I said, "this isn't going to work in the airplaane because we have no autopilot, and I can't be trying to read the checklist for every item in a busy terminal environment. I'll get to the list but its more important to fly airplane right now." Just my 2 cents.
The Twin Bonanza variant on that checklist is:The one I was once taught was the 4 Ms
Mixture
Mags
Master
Miller Time
I find it interesting that there are two flows that are taught at the student pilot level - the preflight walk-around and emergencies. And yet we give so little attention to others.A final note, I do flow checks for emergencies. Opposite some of you posting here, emergencies are the most likely time to have a time/attention critical situation. Fly, flow, then check. Just my 02 of course.
Isn't the point to reduce the amount of time with your head inside the plane? Not to mention proper preflight planning should keep the staring at approaches and sectionals / low enroutes at a minimum.How do you brief approaches, update/teach use of a nav log, or fly with a map then? Staring into the cockpit at paperwork is a routine any pilot should be comfortable with.
Primacy doesn't count as a good reasonI was taught read/do from day one
Pre-landing checks in a typical trainer are 5-8 (8 being retract trainers) items. These are easily performed while on x-wind to downwind or after traffic is in sight and no factor on pattern entry. My training out of Nashua was a class D with typically 5-15 planes in the pattern. So to say it's impractical in busy airspace, well I figure I'll head off that rebuttal.
A checklist is something easy to develop a flow for. It is amazing when watching people fumble around with a checklist while flying while doing the read-do technique. The best is when people lose their spot on the checklist and have to read through everything again to find their spot.
