Hour requirement for Multi Add On
JordanD
Here so I don’t get fined
Is there a minimum amount of hours you need to complete to get your multi add on? I always understood it was like the complex where it just depends on how long it takes you, but I had a flight school tell me the FAA had a minimum number of hours. Did this change, was I flat out wrong, or are they lying to me?
In April of 2011 I got mine with 7 hours total. I don't think there is a minimum amount of flight time required. Hope this helps
No minimum hour requirement for commercial add-on to the same pilot certificate, and that hasn't changed in recent memory as far as I know. 61.63(c)(3), specifically.
-Fox
Next time you go back there, ask them if they can give you a complimentary bucket of prop wash since you will be paying them for those "required...." hours.
They are lying to you...
What they might be referring to is the three hours of prep for a check ride. but to me it sounds like more of a scam.
If they told you, "The FAA requires X amount of hours for the Private Pilot Multi-Engine land add-on", they are incorrect. I agree with AcroFox and Mojo. However, they could have been referring to the insurance requirements for the rental of their multi-engine aircraft. Check back with them for clarification. Also, ask them to provide the FAR for reference about the requirement if they still insist it's an FAA requirement. Out of curiosity, what twin will you be using?
It was a Seminole in an out of state FBO I was checking out. It's the cheapest twin I've found but the cost estimate for the multi had 15 hours of time listed, which seems like a good amount for the multi rating. If I understand right ATP is the 10 hours and if you finish in say, 7, you still have to fly the whole 10.
Check out traverseair based out of Traverse City Michigan. I would bet you cant find someone cheaper. Its like 1500 for his program and 300 for the checkride I beleive.
I just got my multi at queen city in Allentown PA for less than $2000 and in 6 hours.
Fifteen is probably the syllabus- that's what Jepp calls for which I use. I don't believe in quickly teach the check ride ratings especially MEL, though I train to proficiency not hours and have had pilots get it done in about 12 hours (in Senneca II).
Let's see how you do first before we start talking about how long it's gonna take, son! :)
The checkride is just a formality. They really should just go ahead and give it to me.
Roadhouse!
Roadhouse!
Come at me, bro! ROADHOUSE!
I also recommend Traverse Air. I drove 15 hours each way to get there and it was totally worth it to me.
I know a guy who got screwed by a flight schoolon his commercial AMEL add on...Basically, they made him do all of the 61.129 requirements all over again in a twin. Needless to say, the DPE was beyond pissed when he flipped through the guy's log book and decided to not charge him for the checkride (this was about 25 years ago and I do not think the school is around anymore).
